Efficient storage management
The BUFFALO TeraStation WS5020N6 Series offers a robust RAID configuration, supporting RAID 0, RAID 1, and JBOD, allowing for flexible and secure data management. This versatility ensures that data is stored efficiently, with options for redundancy, performance, or a combination of both. -
High-speed connectivity
With a comprehensive suite of networking capabilities including 10 Gigabit Ethernet, 2.5 Gigabit Ethernet, and 5 Gigabit Ethernet, alongside standard Gigabit and Fast Ethernet, this NAS server ensures efficient data transfer rates. This makes it ideal for businesses requiring fast access to large amounts of data across various network protocols. -
Advanced networking features
The device is equipped with advanced networking protocols such as SMB, TCP/IP, and UDP/IP, ensuring seamless integration and compatibility with existing network infrastructures. Its support for Microsoft CIFS, NFS, and SMB protocols allows for easy sharing and access of files across different platforms. -
Durable and reliable design
Designed to operate within a wide range of environmental conditions, the TeraStation WS5020N6 Series can function in temperatures from 0°C to 40°C and humidity levels from 10 to 85% (non-condensing). This durability ensures reliable performance in various operational environments. -
Enhanced data security
Featuring ECC (Error Correcting Code) RAM, the TeraStation WS5020N6 Series provides an added layer of data integrity, automatically detecting and correcting any errors that may occur during data processing. This feature is crucial for businesses where data accuracy is paramount.
- BUFFALO TeraStation WS5020N6 Series WS5220DN04W6EU - NAS server - 4 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet / 10 Gigabit Ethernet
- Total Storage Capacity
- 4 TB
- 17 cm x 23 cm x 17 cm
- 5 kg ()
- Processor
- 1 x Intel Atom C3338 (Dual-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, JBOD
- Hard Drive
- 2 x 2 TB SATA 6Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, 1GbE, 10GbE, 5GbE, 2.5GbE
- RAM
- 8 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Microsoft Windows Storage Server 2016 Workgroup
- System Requirements
- Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Windows 10, Microsoft Windows Server 2016, Apple MacOS X 10.11 - 10.13
- 3-year warranty
- NAS server
- Host Connectivity
- 4 TB
- 17 cm
- 23 cm
- 17 cm
- 5 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 8 GB DDR4
- ECC
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 2 x 2 TB
- Interface Type
- SATA 6Gb/s
- Data Link Protocol
- TCP/IP, UDP/IP, SMB
- Network Services Compatibility
- Microsoft CIFS, Network File System (NFS), Server Message Block (SMB)
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3an, IEEE 802.3bz
- Expansion Bays
- 2 (total) / 0 (free) x hot-swap
- 2 x USB 3.0 - Type A , 1 x Ethernet 10Gb - RJ-45 , 2 x Ethernet 1000Base-T - RJ-45
- LCD display
- Power Device
- Internal power supply
- Voltage Required
- 28.7 Watt
- Power Consumption Stand by
- 5.2 Watt
- Software Included
- NAS Navigator2, NovaBACKUP Buffalo Edition (11 licences)
- OS Required
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
