Buffalo TeraStation 4TB 1400 4 Bay
Quicklinx: BK1GWS00 Mfr#: TS1400D0404-EU
Select:
  • 4 x 1TB
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Buffalo Technology's TeraStation 1400 series (TS1400D) is a four bay storage solution with advanced business features and a strong Dual Issue CPU: perfect for SMB users in need of extra-large capacity and ready to migrate to Network Attached Storage or expand the capacity and features of their existing storage solution.
Users will be impressed with the TS1400D for its business-class feature set and capacities. The TS1400D is ready for intensive data storage tasks: users can choose from multiple levels of RAID support (0/1/5/6/10/JBOD) for customized capacity and redundancy according to their specific needs.
The TS1400D is equipped with the Marvell Armada Dual Issue CPU processor with 512 MB of DDR3 RAM bringing together Buffalo's high performance hardware and architecture and delivering them in a cost-effective solution.
BUFFALO TeraStation 1400 - NAS server - 4 TB
NAS server
Bundled Services
3 years 24-hour TeraStation VIP HDD Exchange Service
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
4 TB
Max Supported Capacity
16 TB
4 (installed) / 4 (max)
17.7 cm x 22.7 cm x 12.75 cm
5.4 kg ()
1 x Marvell ARMADA 370 1.2 GHz (Dual-Core)
Storage Controller
RAID SATA 3Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
Hard Drive
4 x 1 TB SATA 3Gb/s - Full-Automatic Encryption
10Mb LAN, 100Mb LAN, GigE
RAM
512 MB
Storage Operating System
Linux
Microsoft Windows 2000 Server, Microsoft Windows Server 2003, Microsoft Windows Server 2003 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Microsoft Windows Server 2012 (32/64-bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Microsoft Windows RT 8.1, Apple MacOS X 10.4 - 10.9
3-year warranty
NAS server
Bundled Services
Host Connectivity
Gigabit Ethernet
4 TB
16 TB
17.7 cm
22.7 cm
12.75 cm
5.4 kg ()
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
512 MB DDR3
Storage Controller
RAID
Interface Type
SATA 3Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
HDD - hot-swap
4 x 1 TB
Interface Type
SATA 3Gb/s
Network / Transport Protocol
TCP/IP
Remote Management Protocol
HTTP, HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
LDAP support, FTP server, Buffalo Web Access, Apple Time Machine compatible, NTP time synchronisation, SFTP server
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
Expansion Bays
4 (total) / 0 (free) x hot-swap
1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A , 2 x USB 3.0 - Type A
Device-to-device data replication
External power adapter
28 Watt
Linux
Software Included
NovaBACKUP Business Essentials (10 licences)
Limited warranty - 3 years
5 °C
35 °C
20 - 80% (non-condensing)
BK1G C2G 2m USB 2.0 A/B Cable - Black In Stock £4.17
