Buffalo's new TeraStation rackmount enclosure (TS4400R-EU) joins Buffalo's TeraStation family with customizable Network Attached Storage with greater flexibility - users can start by installing one drive and add up to three additional drives as storage and back-up requirements grow.
TeraStation 4400R is equipped with the powerful Intel Atom D2700 Dual-Core Processor and will impress users with both faster transfer of large files and faster file access from multiple computers. Its top-of-class performance is perfect for demanding small, medium, and growing businesses.
When populated with two or more drives the TeraStation 4400R protects your data with RAID and hot swap functionality allows users to change disks without downtime. Another added bonus: the new TeraStation enclosure also comes with 10 free NovaStor NovaBACKUP licenses.
The TS4400R also provides important features to support your business such as Active Directory support, IP camera recording, iSCSI target, a faster and easy-to-use interface, and 2GB of fast DDR3 memory installed. All of this, together with two Gigabit Ethernet ports, two super speed USB 3.0 ports and two high speed USB 2.0 ports, gives users a fast, versatile, and feature-rich NAS enclosure. Buffalo's TS4400R-EU enclosure is compatible with 1, 2, 3, and 4TB drives (sold separately).
- BUFFALO TeraStation 4400R - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable
- Max Supported Capacity
- 16 TB
- Installed Devices / Modules Qty
- 0 (installed) / 4 (max)
- 43 cm x 42 cm x 4.43 cm
- 6.2 kg ()
- Processor
- 1 x Intel Atom D2700 (Dual-Core)
- Storage Controller
- RAID SATA 3Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
- Hard Drive
- SATA 3Gb/s - Full-Automatic Encryption
- Networking
- Network adapter 10Mb LAN, 100Mb LAN, GigE
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 2000 Server, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Apple MacOS X 10.4 - 10.8
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable
- Total Storage Capacity
- 0 GB
- 16 TB
- 43 cm
- 42 cm
- 4.43 cm
- 6.2 kg ()
- Built-in Devices
- Status LCD
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 2 GB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD - hot-swap
- Interface Type
- SATA 3Gb/s
- Network adapter
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, GigE
- TCP/IP
- Remote Management Protocol
- SNMP, HTTP, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
- LDAP support, DFS support, Buffalo Web Access, Direct Copy, Apple Time Machine compatible, NTP time synchronisation
- Expansion Bays
- 4 (total) / 4 (free) x hot-swap
- 2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x serial - DB-9
- Device-to-device data replication
- Power Device
- Internal power supply
- Voltage Required
- 96 Watt
- Software Included
- NovaBACKUP Business Essentials (10 licences), SoleraTec Phoenix RSM (1 license), Buffalo Surveillance Server
- OS Required
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.86 |
