Buffalo TeraStation 4200/2TB (2 x 1TB WD RED HDDs) 2 Bay Desktop NAS
Quicklinx: BVFNWS00 Mfr#: TS4200D/2TB-RED
  • Atom
  • Windows 8 (32/64 bits)
Buffalo's TeraStation enclosure (TS4200D-EU) joins Buffalo's TeraStation family with customisable network attached storage with greater flexibility - users can start by installing one drive and add another drive as storage and back-up requirements grow.
TeraStation 4200 is equipped with the powerful Intel Atom D2550 dual-core processor and will impress users with both faster transfer of large files and faster file access from multiple computers. Its top-of-class performance is perfect for demanding small, medium, and growing businesses.
When populated with two drives the TeraStation 4200 protects your data with RAID and hot swap functionality allows users to change disks without downtime.
  • Versatile connectivity
    With interfaces for Ethernet 1000Base-T, USB 2.0, USB 3.0, and serial connections, the BUFFALO TeraStation 4200D offers a variety of options for integrating into existing networks and systems, ensuring seamless data transfer and access.
  • Robust data protection
    Featuring RAID 0, RAID 1, and JBOD configurations, the TeraStation 4200D provides flexible options for data management and security, allowing users to tailor the storage solution to their specific needs for redundancy and performance.
  • Comprehensive network compatibility
    Supporting a wide range of network protocols and services including Ethernet, Fast Ethernet, Gigabit Ethernet, and compatibility with Apple Time Machine, Microsoft Active Directory, and more, this NAS server ensures broad compatibility and easy integration into diverse IT environments.
BUFFALO TeraStation 4200D - NAS server - 2 TB
NAS server
Bundled Services
3 years 24-hour TeraStation VIP HDD Exchange Service
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
2 TB
2 (installed) / 2 (max)
17 cm x 23 cm x 17 cm
3.15 kg ()
1 x Intel Atom D2550 1.86 GHz (Dual-Core)
Storage Controller
RAID SATA 3Gb/s RAID RAID 0, 1, JBOD
Hard Drive
2 x 1 TB SATA 3Gb/s - Full-Automatic Encryption
10Mb LAN, 100Mb LAN, GigE
RAM
2 GB
Storage Operating System
Linux
Microsoft Windows 2000, Microsoft Windows 2000 Server, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows XP Media Center Edition 2004, Microsoft Windows XP Media Center Edition 2005, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Windows 8.1, Apple MacOS X 10.4 - 10.9
3-year warranty
NAS server
Bundled Services
Host Connectivity
Gigabit Ethernet
2 TB
17 cm
23 cm
17 cm
3.15 kg ()
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
2 GB DDR3
Storage Controller
RAID
Interface Type
SATA 3Gb/s
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - hot-swap - 3.5"
2 x 1 TB
Interface Type
SATA 3Gb/s
Network / Transport Protocol
TCP/IP
Remote Management Protocol
SNMP, HTTP, HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), DFS, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
LDAP support, wake on LAN (WOL), print server, FTP server, Buffalo Web Access, BitTorrent Client, Direct Copy, DLNA Media Server, Apple Time Machine compatible, NTP time synchronisation, SFTP server
DLNA CERTIFIED
Expansion Bays
2 (total) / 0 (free) x hot-swap
2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 2 x USB 3.0 - Type A , 1 x serial - DB-9
Device-to-device data replication
Internal power supply
86 Watt
Linux
Software Included
NovaBACKUP Business Essentials (10 licences), SoleraTec Phoenix RSM (1 license), Buffalo Surveillance Server
Limited warranty - 3 years
5 °C
20 - 80% (non-condensing)
