Buffalo TeraStation 3420RN 4TB (4 x 1TB) 4 Bay Rack Mountable
Quicklinx: FG1JWS00 Mfr#: TS3420RN0404-EU
Marketing description is not available.
  • Rsynch feature
    Users can make backup copies from TeraStation to an rsync-compatible device from another manufacturer. This function also allows backups to be made from another manufacturer's rsync-compatible NAS to the TeraStation NAS.
  • Active directory
    TeraStation functions as a client of an Active Directory domain, so that domain users and groups can be used. This means that they can be used in domain environments of companies with up to 10,000 users and groups.
  • Hot-swap function increases data security
    With the hot swap function, the TeraStation automatically switches off the defective hard disk even if one hard disk fails, so that it can be replaced safely without interrupting work or losing data.
  • Cloud-ready
    Buffalo's TeraStation Series features B-Sync, which allows users to easily synchronize files between their TeraStation and 3rd party cloud services to make backups. The Buffalo NAS supports Amazon S3 Cloud Services, Dropbox, OneDrive and Azure.
  • Intuitive web management interface
    The web interface has a dashboard that offers the user more effective views of system status, the ability to resize windows (even on the phone) and a more comfortable button layout.
  • Replication with TeraStation
    By replication, a folder in two separate TeraStations is synchronized almost in real time. This only happens in one direction (not bi-directional) - from the source to the destination. This function can be set up in LAN and WAN. WAN setup includes remote connection via port forwarding and VPN setup.
BUFFALO TS3420RN Series TS3420RN0404 - NAS server - 4 TB
NAS server
Host Connectivity
2.5 Gigabit Ethernet
Enclosure Type
Rack-mountable
Total Storage Capacity
4 TB
4 (installed) / 4 (max)
43 cm x 43 cm x 4.43 cm
8.6 kg ()
Europe
1 x Annapurna Labs Alpine AL-214 1.4 GHz (Quad-Core)
Storage Controller
RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10
Hard Drive
4 x 1 TB SATA 6Gb/s
10Mb LAN, 100Mb LAN, 1GbE, 2.5GbE
RAM
1 GB
AC 100 V (50/60 Hz)
3-year warranty
NAS server
Host Connectivity
Enclosure Type
Rack-mountable
4 TB
43 cm
43 cm
4.43 cm
8.6 kg ()
Built-in Devices
Status LCD
Europe
Processor / Memory
Processors Installed
Number of Cores
Quad-Core
Max Supported Qty
1
RAM
1 GB DDR3
Storage Controller
RAID
Interface Type
SATA 6Gb/s
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10
Hard Drive
HDD - hot-swap
4 x 1 TB
Interface Type
SATA 6Gb/s
Network / Transport Protocol
TCP/IP, FTP, SMB, SFTP
Remote Management Protocol
SNMP, HTTP, HTTPS
Network Services Compatibility
Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, SFTP
Wake on LAN (WOL), full duplex mode, Buffalo Web Access, Apple Time Machine compatible, 2 fans, secure backup, port trunking
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3an, IEEE 802.3bz
Expansion Bays
4 (total) / 0 (free) x hot-swap - 3.5"
1 x 2.5 Gigabit Ethernet - RJ-45 , 2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 - Type A
1 x network cable - 2 m
Built-in 2 cooling fans
RoHS, VCCI Class A, Green Purchasing Law
Rack mounting kit
Internal power supply
AC 100 V (50/60 Hz)
85 Watt
Limited warranty - 3 years
10 - 85% (non-condensing)
