BUFFALO's MiniStation Extreme offers high performance USB3.0 portable storage in a compact and sophisticated design. The internal hard drive is encased in a highly shock-resistant body with rubberized elements to protect it from accidental bumps.
US military grade (MIL-SPEC) shock protection
Shock absorbers surround the hard disk protecting it from damage and drops from up to 2 meters. -
Flex connect USB cable
Removable, integrated USB cable snaps to chassis for improved portability. -
Hardware disk encryption
Automatic 256-bit AES Full Disk Encryption (FDE) protects your data from unauthorized access. -
Compact and sleek
Slim, lightweight chassis saves space for ultimate portability. -
USB powered
Perfect companion for your laptop or netbook - no external power supply needed. -
Connect and go
Preformatted hard drive is ready for immediate use with Windows and Mac. -
Buffalo tools
A feature-rich software suite of tools designed to boost PC performance. -
Back up your files
Bu ffalo's backup utility automatically backs up your Windows PC, protecting your data. -
Time Machine compatibility
Works perfectly with Time Machine to back up your Mac computer. -
Eco manager
Eco minded power management tool regulates power usage, conserving energy and battery consumption.
- BUFFALO MiniStation Extreme - hard drive - 1 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 1 TB
- Hardware Encryption
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Shock resistant, water resistant, Hardware Full Disk Encryption (FDE), dust-proof, wrap-around USB cable, Apple Time Machine compatible, 256-bit AES
- Power Source
- USB bus
- Enclosure Colour
- Red
- 9 cm x 14.1 cm x 2.1 cm
- 277 g
- 2-year warranty
- Capacity
- 1 TB
- Interface
- USB 3.0
- Internal Drive Interface
- SATA 3 Gb/s
- 9 cm
- 14.1 cm
- 2.1 cm
- 277 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0 - 10 pin Micro-USB Type B
- Power Source
- USB bus
- OS Required
- Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.7 or later, Windows 8, Windows 8.1 RT, Windows 8.1, Windows RT
- Cables Included
- 1 x USB 3.0 cable - integrated
- MIL-STD 810G 516.6, IP5X, IPX3
- Enclosure Colour
- Red
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
