Buffalo's MiniStation Portable USB Hard Drive offers a compact, sleek, lightweight and portable storage solution. Store, back up and transport digital images, music and other files without taking up space on your PC's hard drive.
Portable design
The BUFFALO MiniStation external hard drive boasts a portable design, making it an ideal companion for users on the go. Its compact size allows for easy transportation, ensuring your data is always within reach. -
Efficient power
Powered directly through the USB bus, the BUFFALO MiniStation eliminates the need for an external power source, offering a streamlined and efficient user experience. This feature ensures that users can access their files without the hassle of carrying additional cables or adapters.
- BUFFALO MiniStation HD-PCF2.0U3BD-WR - hard drive - 2 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 2 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Bus Powered by USB
- Power Source
- USB bus
- Enclosure Colour
- Black
- 76 mm x 115 mm x 19.5 mm
- 225 g
- 2-year warranty
- Capacity
- 2 TB
- Interface
- USB 3.0
- Internal Drive Interface
- Serial ATA
- 76 mm
- 115 mm
- 19.5 mm
- 225 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0 - 10 pin Micro-USB Type B
- Power Source
- USB bus
- OS Required
- Microsoft Windows Vista / 7 / 8 / 8.1 / 10, Apple MacOS X 10.7 or later
- Plug and Play
- Enclosure Colour
- Black
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
