Buffalo's LinkStation Pro Duo is the ideal solution to keep important files safe! Stream your favorite music and videos directly from the LinkStation Pro Duo to a computer, PS3, Xbox 360 or network attached DLNA or UPnP media player or Buffalo LinkTheater. With ultra fast data transfer speeds, the LinkStation Pro Duo is a high performance dual drive that can be configured in RAID 0 for performance or RAID 1 for redundant storage. If a drive does fail, you have a copy of your data on the second drive. Easy to install, the LinkStation Pro Duo lets you store and share your music, photos, and videos in your home or small office.
- BUFFALO LinkStation Pro Duo - NAS server - 2 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 2 TB
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- 8.6 cm x 12.7 cm x 20.4 cm
- 1.7 kg ()
- Storage Controller
- RAID SATA 1.5Gb/s RAID 0, 1
- Hard Drive
- 2 x 1 TB SATA 1.5Gb/s
- Networking
- Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows XP Media Center Edition 2004, Microsoft Windows 7, Microsoft Windows XP Media Center Edition 2005, Apple MacOS X 10.3.9 or later, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits)
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 2 TB
- 8.6 cm
- 12.7 cm
- 20.4 cm
- 1.7 kg ()
- Built-in Devices
- Print server
Storage Controller
- RAID - internal
- Interface Type
- SATA 1.5Gb/s
- Supported Devices
- Hard drive, disk array (RAID)
- RAID Level
- RAID 0, RAID 1
Hard Drive
- HDD
- Capacity
- 2 x 1 TB
- Interface Type
- SATA 1.5Gb/s
- 128-bit AES
- Data Link Protocol
- TCP/IP, NTP, FTP
- Remote Management Protocol
- HTTP
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Server Message Block (SMB), Apple File Protocol (AFP)
- Print server, BitTorrent Client, Direct Copy
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED
- Expansion Bays
- 2 (total) / 0 (free) x internal
- 1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A
- Power Device
- External power adapter
- Voltage Required
- 24 Watt
- Software Included
- NovaBACKUP Workstation - Buffalo Edition (5 licences)
- OS Required
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
