Buffalo LinkStation Pro Duo 2TB
Quicklinx: 77N4WS00 Mfr#: LS-WV2.0TL/R1-EU
Buffalo's LinkStation Pro Duo is the ideal solution to keep important files safe! Stream your favorite music and videos directly from the LinkStation Pro Duo to a computer, PS3, Xbox 360 or network attached DLNA or UPnP media player or Buffalo LinkTheater. With ultra fast data transfer speeds, the LinkStation Pro Duo is a high performance dual drive that can be configured in RAID 0 for performance or RAID 1 for redundant storage. If a drive does fail, you have a copy of your data on the second drive. Easy to install, the LinkStation Pro Duo lets you store and share your music, photos, and videos in your home or small office.
BUFFALO LinkStation Pro Duo - NAS server - 2 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
2 TB
2 (installed) / 2 (max)
8.6 cm x 12.7 cm x 20.4 cm
1.7 kg ()
Storage Controller
RAID SATA 1.5Gb/s RAID 0, 1
Hard Drive
2 x 1 TB SATA 1.5Gb/s
Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows XP Media Center Edition 2004, Microsoft Windows 7, Microsoft Windows XP Media Center Edition 2005, Apple MacOS X 10.3.9 or later, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits)
NAS server
Host Connectivity
Gigabit Ethernet
2 TB
8.6 cm
12.7 cm
20.4 cm
1.7 kg ()
Built-in Devices
Print server
Storage Controller
RAID - internal
Interface Type
SATA 1.5Gb/s
Supported Devices
Hard drive, disk array (RAID)
RAID Level
RAID 0, RAID 1
Hard Drive
HDD
2 x 1 TB
Interface Type
SATA 1.5Gb/s
128-bit AES
Network / Transport Protocol
TCP/IP, NTP, FTP
Remote Management Protocol
HTTP
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, Server Message Block (SMB), Apple File Protocol (AFP)
Print server, BitTorrent Client, Direct Copy
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED
Expansion Bays
2 (total) / 0 (free) x internal
1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A
External power adapter
24 Watt
Software Included
NovaBACKUP Workstation - Buffalo Edition (5 licences)
5 °C
35 °C
20 - 80% (non-condensing)
