The LinkStation Live II is a Multimedia shared network storage device best suited for environments that need a central location for files that all devices on the network can access. All computers in the network can share files on this versatile, flexible and simple NAS. In addition to the storage capabilities, it can stream multimedia to a PC, a Mac, a Buffalo LinkTheater and other DLNA CERTIFIED media players. The LinkStation Live seamlessly integrates with iTunes 7 and allowing access to music files from your iTunes software.
- BUFFALO LinkStation Live with BitTorrent - NAS server - 1 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 1 TB
- 4.5 cm x 15.6 cm x 17.5 cm
- 1.13 kg ()
- Localisation
- Europe
- Storage Controller
- SATA SATA 1.5Gb/s
- Hard Drive
- 1 x 1 TB SATA 1.5Gb/s
- Networking
- Network adapter - integrated - 10Mb LAN, 100Mb LAN, 1GbE
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Apple MacOS X 10.3.9 or later, Microsoft Windows Vista, Microsoft Windows Server 2008
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 1 TB
- 4.5 cm
- 15.6 cm
- 17.5 cm
- 1.13 kg ()
- Built-in Devices
- Print server
- Localisation
- Europe
Storage Controller
- SATA - internal
- Interface Type
- SATA 1.5Gb/s
- Supported Devices
- Hard drive
Hard Drive
- HDD
- Capacity
- 1 x 1 TB
- Interface Type
- SATA 1.5Gb/s
- Data Transfer Rate
- 150 MBps
- Spindle Speed
- 7200 rpm
- Data Link Protocol
- TCP/IP, NTP, FTP, SMB
- Remote Management Protocol
- HTTP
- Network Services Compatibility
- FTP, Server Message Block (SMB), HTTP
- Print server, iTunes server, Jumbo Frames support, FTP server, Buffalo Web Access, BitTorrent Client, Direct Copy
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED
- Expansion Bays
- 1 (total) / 0 (free) x internal
- 1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A
- Power Device
- Internal power supply
- Voltage Required
- 17 Watt
- Software Included
- NovaBACKUP Workstation - Buffalo Edition (5 licences)
- OS Required
- Limited warranty - 2 years
