Buffalo Technology's LinkStation 520D series is a customizable, large capacity Network Attached Storage solution with great flexibility.
The LS520D features a robust dual core processor and is super-fast with impressive start-up and shut down speed as well as read and write speeds up to 110 MB/s!
The LS520 makes intensive data storage tasks easy, and users can choose from RAID 0/1/JBOD support for customized capacity and redundancy according to their specific needs.
LS520 users will enjoy its intuitive and quick interface and expanded power control features which include on/off scheduling, Wake on LAN, and HDD spin down. Thus enabling the LS520 to stop working when you do and greatly lessen its power consumption.
Powerful backup NovaBACKUP
NovaBACKUP automatically backs up your personal documents along with your favorite photos, music and videos, and protects your data on workstations locally and online. Regardless of theft, user error or hardware failure, NovaBACKUP keeps your data secure. -
Gigabit Ethernet port 10/100/1000
Gigabit Ethernet port enabled for high-speed network connectivity. -
Restricted access
Set user access and security levels to protect data. -
Seamlessly wired to iTunes
Access music files stored on your LinkStation 520 with your iTunes software. -
Backup for multiple Mac computers
Supports Apple Time Machine - for backing up multiple Mac computers.
- BUFFALO LinkStation 520D - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Max Supported Capacity
- 16 TB
- Installed Devices / Modules Qty
- 0 (installed) / 2 (max)
- 8.7 cm x 20.5 cm x 12.6 cm
- 2.5 kg ()
- Processor
- 1 x Realtek Semiconductor 1 GHz (Dual-Core)
- Storage Controller
- RAID SATA 3Gb/s RAID RAID 0, 1, JBOD
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 256 MB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Apple MacOS X 10.7 or later, Microsoft Windows 7 / 8 / 8.1 / 10
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- 16 TB
- 8.7 cm
- 20.5 cm
- 12.6 cm
- 2.5 kg ()
- Enclosure Colour
- Black
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 256 MB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, JBOD
- Data Link Protocol
- TCP/IP
- Remote Management Protocol
- HTTP
- Network Services Compatibility
- Apple Bonjour Protocol, Microsoft CIFS, FTP, Server Message Block (SMB), Apple File Protocol (AFP)
- Wake on LAN (WOL), iTunes server, BitTorrent Client, DLNA Media Server, Apple Time Machine compatible, NTP time synchronisation
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED
- Expansion Bays
- 2 (total) / 2 (free) x internal - 3.5"
- 1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 3.0 - Type A
- Cables Included
- 1 x network cable
- Power Device
- External power adapter
- Voltage Required
- 37 Watt
- Software Included
- NovaBACKUP Buffalo Edition (5 licences)
- OS Required
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.86 |
