LinkStation™ 520 - Network Attached Storage: Fast Forward
Buffalo™ Technology’s LinkStation™ 520D series is a customisable, large capacity Network Attached Storage solution with great flexibility.
The LS520D features a robust Dual Core processor and is super-fast with impressive start-up and shut down speed as well as read and write speeds up to 100 MB/s!
The LS520 makes intensive data storage tasks easy, and users can choose from RAID (Linear/0/1) support for customised capacity and redundancy according to their specific needs. Backups are also made easy with NovaStor’s NovaBACKUP Buffalo Edition for PC, or TimeMachine for Mac.
LS520 users will enjoy its intuitive and quick interface and expanded power control features which include on/off scheduling, Wake on LAN, and HDD spin down. Thus enabling the LS520 to stop working when you do and greatly lessen its power consumption.
Buffalo’s LS520 is also DLNA compatible and works with 3rd party File Management apps for Android and iOS to help you step-up your Digital Life and/or seamlessly blend in to your existing set-up.
Sorry NSA – The Truly Private Cloud
Buffalo’s Private Cloud solution ensures your privacy and comes without any monthly fees. With a private cloud users’ data stays protected in the physical location of your device – not off-site in a third party’s data centre. And with Buffalo’s free mobile and tablet Apps, or any web browser, your data is accessible and just a couple keystrokes away.
• Big capacity
• No size limitation for each file
• No transfer size limitation per day
WebAccess - Free Apps and One-click Access from Anywhere
While on the go, Buffalo's free WebAccess service allows users to create a private cloud for easy remote access and file sharing with anyone, anywhere over the Internet. All you need is a Smartphone or tablet and Buffalo's free iOS, Windows or Android app to enjoy full access to the digital assets you keep on your LinkStation™ 520.
Organize Your Life
Ideal for home users, the new LinkStation 520 Series provides simple network storage and backup and offers an assortment of features, allowing users to store, organize, access and stream media files from any computer, smartphone or tablet.
Buffalo’s new LinkStation™ can also stream up to 4 HD films simultaneously allowing each family member to watch their favourite film, on their own device, at the same time.
NovaBACKUP® Buffalo Edition for PC
The LinkStation™ 520 is bundled with five licenses of NovaBACKUP® Buffalo Edition. NovaBACKUP® automatically backs up your personal documents along with your favorite photos, music and videos, and protects your data on workstations locally and online. Regardless of theft, user error or hardware failure, NovaBACKUP® keeps your data secure.
Backup for multiple Mac computers
Supports Apple Time Machine -- for backing up multiple Mac computers.
Built-in BitTorrent
Download media files directly to your LinkStation™ 520 without having to power up your PC with the built-in BitTorrent™ client. A BitTorrent™ client is a programme that uses the BitTorrent™ protocol to manage large file downloads and uploads over the Internet.
Gigabit Ethernet port 10/100/1000
Gigabit Ethernet port enabled for high-speed network connectivity.
Seamlessly Wired to iTunes
Access music files stored on your LinkStation™ 520 with your iTunes software.
Powerful backup NovaBACKUP
NovaBACKUP automatically backs up your personal documents along with your favorite photos, music and videos, and protects your data on workstations locally and online. Regardless of theft, user error or hardware failure, NovaBACKUP keeps your data secure. -
Gigabit Ethernet port enabled for high-speed network connectivity. -
Restricted access
Set user access and security levels to protect data. -
Seamlessly wired to iTunes
Access music files stored on your LinkStation 520 with your iTunes software. -
Supports Apple Time Machine - for backing up multiple Mac computers.
- BUFFALO LinkStation 520D - NAS server - 2 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 2 TB
- Max Supported Capacity
- 8 TB
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- 8.7 cm x 20.5 cm x 12.6 cm
- 2.5 kg ()
- Processor
- 1 x 1.1 GHz (Dual-Core)
- Storage Controller
- RAID SATA 3Gb/s RAID RAID 0, 1, JBOD
- Hard Drive
- 2 x 1 TB SATA 3Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 256 MB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.7 or later, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 2 TB
- 8 TB
- 8.7 cm
- 20.5 cm
- 12.6 cm
- 2.5 kg ()
- Enclosure Colour
- Black
Processor / Memory
- Processors Installed
- 1 x 1.1 GHz
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 256 MB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD - 3.5"
- Capacity
- 2 x 1 TB
- Interface Type
- SATA 3Gb/s
- Data Link Protocol
- TCP/IP
- Remote Management Protocol
- HTTP
- Network Services Compatibility
- Apple Bonjour Protocol, Microsoft CIFS, FTP, Server Message Block (SMB), Apple File Protocol (AFP)
- Wake on LAN (WOL), iTunes server, BitTorrent Client, DLNA Media Server, Apple Time Machine compatible, NTP time synchronisation
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED
- Expansion Bays
- 2 (total) / 0 (free) x internal
- 1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 3.0 - Type A
- Power Device
- External power adapter
- Voltage Required
- 37 Watt
- Software Included
- NovaBACKUP Buffalo Edition (5 licences)
- OS Required
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.02 |
