Buffalo Technology's LinkStation 441D series is a complete network storage solution for small business and home office with potentially huge capacity and great flexibility. Buffalo's NAS is a 4 bay customisable storage solution that comes with Buffalo's free and private personal cloud keeping your data both accessible and secure.
The LS441D is ready for intensive data storage tasks and when fully populated, users can choose from multiple levels of RAID support for customized capacity and redundancy according to their specific needs.
And no matter where you go, all your data is accessible from any web browser or with Buffalo's free Apps for Android, iOS, and Windows Phone. And with Buffalo's Private Cloud solution users' data stays protected in the physical location of the device - not off-site in a third party's data center.
Back at home, Buffalo's LinkStation is DLNA compatible, and Twonky Beamready, and can stream multiple HD films simultaneously allowing each family member to watch their favorite film, on their own device, at the same time. The LS441 can also stream high-end DSD audio files without losing quality.
The LS441D is also mobile-friendly and can even be set up via smartphones with a mobile-optimized and intuitive interface.
Versatile storage options
The BUFFALO LinkStation 441D NAS server offers a range of RAID configurations including JBOD, RAID 0, RAID 1, RAID 10, and RAID 5, allowing for customized storage solutions tailored to specific needs and data protection levels. -
Comprehensive connectivity
Equipped with Gigabit Ethernet and multiple USB ports, including USB 2.0 and USB 3.0, this device ensures high-speed data transfer and connectivity options for a variety of peripherals and network environments. -
Enhanced media and file support
With features like DLNA Media Server, Apple Time Machine compatibility, and BitTorrent Client, the LinkStation 441D serves as a versatile media hub, supporting a wide range of file protocols and services for seamless access and sharing. -
Reliable performance
Powered by a Marvell ARMADA dual-core processor with 1.2 GHz and DDR3 SDRAM, this NAS server delivers reliable and efficient performance for everyday data management and streaming tasks. -
Easy remote access and management
Buffalo's Web Access and support for multiple remote management protocols, including HTTP and HTTPS, allow for easy access and management of files remotely, enhancing productivity and convenience for users.
- BUFFALO LinkStation 441D - NAS server - 16 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 16 TB
- Max Supported Capacity
- 16 TB
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- 17.7 cm x 22.7 cm x 12.75 cm
- 5.4 kg ()
- Processor
- 1 x Marvell ARMADA 370 1.2 GHz (Dual-Core)
- Storage Controller
- RAID SATA 3Gb/s RAID RAID 0, 1, 5, 10, JBOD
- Hard Drive
- 4 x 4 TB SATA 3Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 512 MB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows XP, Microsoft Windows XP Media Center Edition 2004, Microsoft Windows XP Media Center Edition 2005, Apple MacOS X 10.6 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Phone 7, Windows 8 (32/64 bits), Android 2.3 or later, Microsoft Windows Server 2012 (32/64-bits), Apple iOS 5.0 or later, Windows 8.1 (32/64 bits), Windows Phone 8, Microsoft Windows RT 8.1, Microsoft Windows RT 8
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 16 TB
- 16 TB
- 17.7 cm
- 22.7 cm
- 12.75 cm
- 5.4 kg ()
- Enclosure Colour
- Black
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 512 MB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10, JBOD
Hard Drive
- HDD - 2.5" / 3.5" shared
- Capacity
- 4 x 4 TB
- Interface Type
- SATA 3Gb/s
- Data Link Protocol
- TCP/IP, Bonjour
- Remote Management Protocol
- HTTP, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
- iTunes server, Buffalo Web Access, BitTorrent Client, DLNA Media Server, Apple Time Machine compatible, NTP time synchronisation
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED
- Expansion Bays
- 4 (total) / 0 (free) x internal - 2.5" / 3.5"
- 1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A , 2 x USB 3.0 - Type A
- UPS support
- Power Device
- External power adapter
- Voltage Required
- 28 Watt
- Software Included
- NovaBACKUP Workstation - Buffalo Edition (5 licences)
- OS Required
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £3.56 |
