Buffalo's new LinkStation has the latest CPU with a new generation CPU core for noticeably improved performance that delivers transfer speeds up to 100MB/s!
High performance home data and media server
Buffalo's LinkStation 410 is a high performance 1-drive network storage device that comes equipped with a whole host of features, perfect for storing, sharing, serving and protecting your most important data. Back up multiple PCs and Mac computers simultaneously and enjoy uninterrupted access to terabytes of storage on your network and even over the Internet while away from home. -
Secure central storage
With terabytes of storage, LinkStation 410 provides a reliable, central location to store all data from every PC and Mac computer, tablet device and smartphone in your home or small office. Store, access and share files from anywhere over your wireless network at speeds up to three times as fast as a standard NAS device! -
Exceptional performance
Equipped with a high performance processor, LinkStation 410 offers much more than simple home shared storage. This single drive network storage device boasts transfer speeds up to 100 Mbps, nearly twice as fast as a USB 2.0 drive and three times faster than a standard NAS device. -
Stream your favorite media
LinkStation 410 is DLNA Certified and it can be used as an iTunes server to stream all of your favorite music, movies and shows to multiple devices simultaneously. Now you can relax and watch movies on your big screen TV while music is pumped outdoors by the pool. Centralize your media files for simple sharing and streaming. -
Easy scheduled backup
LinkStation 410 features NovaBACKUP Professional for Windows and Time Machine support for Mac for whole home data backup. Disaster and hard drive failures happen unexpectedly; don't leave your important files and treasured memories in the hands of chance. Schedule backups for every computer in your house and easily protect all of your data, down to the very last byte.
- BUFFALO LinkStation 410 - NAS server - 2 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 2 TB
- Max Supported Capacity
- 4 TB
- 4.5 cm x 20.5 cm x 12.8 cm
- 1.3 kg ()
- Processor
- 1 x Marvell ARMADA 370 1.2 GHz (Dual-Core)
- Storage Controller
- SATA SATA 3Gb/s
- Hard Drive
- 1 x 2 TB SATA 3Gb/s
- Networking
- Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
- RAM
- 512 MB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 2 TB
- 4 TB
- 4.5 cm
- 20.5 cm
- 12.8 cm
- 1.3 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 512 MB DDR3
Storage Controller
- SATA
- Interface Type
- SATA 3Gb/s
Hard Drive
- HDD
- Capacity
- 1 x 2 TB
- Interface Type
- SATA 3Gb/s
- Data Link Protocol
- TCP/IP
- Remote Management Protocol
- HTTP, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
- Print server, iTunes server, Buffalo Web Access, BitTorrent Client, DLNA Media Server, Apple Time Machine compatible, NTP time synchronisation
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED, UPnP
- 1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A
- Power Device
- External power adapter
- Voltage Required
- 24 Watt
- Software Included
- NovaBACKUP Workstation - Buffalo Edition (5 licences)
- OS Required
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
