The Buffalo DriveStation Duo USB 3.0 is a high performance, multimedia, external hard drive perfect for the home or small office that requires large amounts of storage space. The unit is a two-drive; two-bay RAID enabled drive with RAID 0 for performance and RAID 1 for redundant storage. The DriveStation Duo gives additional storage to quickly backup all your multimedia files.
The DriveStation Duo USB 3.0 features the capacity, redundancy and performance required for any demanding user, the perfect solution for backing up large servers or multimedia files.
Enhanced compatibility
Designed to seamlessly integrate with both Mac and PC systems, the BUFFALO DriveStation Duo USB 3.0 offers versatile compatibility, ensuring users can easily connect to their preferred devices without compatibility concerns. -
Robust storage solution
Featuring two installed HDDs with support for RAID 0 and RAID 1 configurations, this hard drive array provides a reliable storage solution, enabling users to optimize for speed or data redundancy according to their needs. -
High-speed connectivity
Equipped with USB 3.0 interface, the DriveStation Duo ensures fast data transfer rates, making it easier and more efficient to move large files, enhancing productivity and reducing wait times.
- BUFFALO DriveStation Duo USB 3.0 - hard drive array
- Hard drive array
- Total Array Capacity
- 4 TB
- Interface
- USB 3.0
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- Supported Drives
- SATA-300
- Storage Controller
- RAID (SATA 3Gb/s) - RAID RAID 0, 1
- Hard Drive
- 2 x 2 TB HDD SATA 3Gb/s
- OS Required
- Microsoft Windows XP, Microsoft Windows Server 2003, Apple MacOS X 10.4 or later, Microsoft Windows Server 2003 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits)
- Power
- AC 120/230 V - 50/60 Hz
- 8.6 cm x 20.4 cm x 12.7 cm
- 2 kg
- 2-year warranty
- Hard drive array
Chassis
- 2
- Supported Devices / Modules Qty
- 2
- Supported Drives
- SATA-300
Storage
- 4 TB
- HDD Array External Interface
- USB 3.0
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1
Hard Drive
- HDD
- Capacity
- 2 x 2 TB
- Interface Type
- SATA 3Gb/s
- Expansion Bays
- 2 (total) / 0 (free) x external
- 1 x USB 3.0
- OS Required
- Software Included
- SecureLockWare, Buffalo Tools, NovaBACKUP Business Essentials
- Power Device
- External power adapter
- Voltage Required
- 36 Watt
- 8.6 cm
- 20.4 cm
- 12.7 cm
- 2 kg
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.17 |
