Buffalo AirStation 1300 Gigabit Dual Band Media Bridge
Quicklinx: 84VLWS00 Mfr#: WLI-H4-D1300-EU
  • IEEE 802.11n
AirStation™ 1300 Gigabit Dual Band Media Bridge is a versatile dual band solution that extends the capabilities of your wireless network. Connect up to four network enabled wired devices, such as media players and gaming consoles to your existing wireless network for high speed data streaming.
With two wireless radios for extreme performance and backward compatibility, AirStation™ 1300 supports 802.11ac and 802.11n, offering transfer speeds up to 1.3Gbps in the 5GHz spectrum or 450Mbps on the 2.4GHz band.
With four gigabit Ethernet ports and backward compatibility, AirStation™ 1300 offers extreme performance and is a perfect addition to any existing wireless network.
  • Dual band
    Offering selectable dual band wireless operation on the 2.4 GHz and 5 GHz bands, the AirStation AC1300/N450 Gigabit Dual Band Wireless Ethernet Bridge is perfect for streaming HD movies, music and emailing from multiple devices at the same time.
  • Fast wireless connectivity
    With 5 GHz speeds up to 1300 Mbps and 2.4 GHz speeds up to 450 Mbps, AirStation AC1300/N450 Gigabit Dual Band Wireless Router provides an extremely fast wireless connection, perfect for surfing and emailing from multiple computers, downloading files and streaming music, movies and other HD multimedia content from the Web - all at the same time! Easily connect with your computer, tablet and smartphone devices.
  • Gigabit Ethernet
    Maximize your wired network speed with gigabit Ethernet connections that keep your data moving at lightning speed.
  • Compatibility
    Easily upgrade to your network from previous wireless standards and maintain compatibility with existing adapters and devices. AirStation WZR-D1800H works with 11a, 11g and 11n, offering extreme performance and greater coverage.
  • Easy setup
    AirStation AC1300 / N4500 Gigabit Dual Band Wireless Ethernet Bridge is simple to set up. Use the helpful Web interface to walk you through configuration and connect in minutes. WLI-H4-D1300 also supports Buffalo AOSS and WPS for push-button connection. No drivers or software installation required!
BUFFALO AirStation WLI-H4-D1300 - bridge - 802.11a/b/g/n/ac - desktop
Bridge - 4-port switch (integrated)
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.3 Gbps
Auto-sensing per device, auto-uplink (auto MDI/MDI-X), MAC address filtering, Airstation OneTouch Secure System (AOSS), MIMO technology, Wi-Fi Protected Setup (WPS), Direct Sequence Spread Spectrum (DSSS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
21.2 cm x 3.4 cm x 18.3 cm
500 g
Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple MacOS X 10.4 - 10.7
3-year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.3 Gbps
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, TKIP, WPA-PSK, WPA2-PSK
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45
External power adapter
9.8 Watt
Vertical stand
21.2 cm
3.4 cm
18.3 cm
500 g
Limited warranty - 3 years
20 - 80% (non-condensing)
