Buffalo Technology's TeraStation 1200 series is a two bay storage solution with advanced business features and a strong Dual Issue CPU: perfect for small business users ready to migrate to Network Attached Storage or expand the capacity and features of their existing storage solution.
Users will be impressed with the TS1200D for its business-class feature set including support for RAID 0/1/JBOD, replication. The TS1200D is equipped with the Marvell Armada Dual Issue CPU processor with 512 MB of DDR3 RAM bringing together Buffalo's high performance hardware and architecture and delivering them in a cost-effective solution.
TeraStation NAS System
TeraStation 1200 runs on Buffalo's TeraStation NAS System providing a host of business-class features from network file sharing and security to RAID management, remote access and more. Managing data, backups and data sharing in a production environment or larger business is made easy with this NAS operating system. Included on all Buffalo TeraStation devices, TeraStation NAS System simplifies your everyday data needs. -
Performance with value
TeraStation 1200 features the dual-issue 1.2 GHz ARM processor, providing exceptional performance during file transfers and everyday NAS functions at an unbeatable value. -
Reliable and secure
TeraStation 1200 offers high capacity, highly available storage accessible among multiple platforms for seamless centralized storage and backup. Create user and group profiles and control folder and file access to protect business critical content and privacy. -
Data protection and backup
TeraStation 1200 features Buffalo's replication technology providing real-time synchronous replication of data for easy, continuous data protection in the event of data loss. -
Remote file access
TeraStation 1200 offers multiple ways to remotely access and share your important data for enhanced collaboration and productivity. With WebAccess and FTP/SFTP servers, you can securely access and share files with anyone outside the local network. Trusted recipients can access selected files from anywhere over the Internet, and with WebAccess files can also be accessed remotely from tablet and smartphone devices.
- BUFFALO TeraStation 1200 - NAS server - 6 TB
- NAS server
- Bundled Services
- 3 years 24-hour TeraStation VIP HDD Exchange Service
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 6 TB
- Max Supported Capacity
- 8 TB
- Installed Devices / Modules Qty
- 2 (installed) / 2 (max)
- 8.7 cm x 20.5 cm x 12.8 cm
- 2.4 kg ()
- Processor
- 1 x Marvell ARMADA 370 1.2 GHz (Dual-Core)
- Storage Controller
- RAID SATA 3Gb/s RAID RAID 0, 1, JBOD
- Hard Drive
- 2 x 3 TB SATA 3Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 512 MB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Linux
- System Requirements
- Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2008 R2 (32/64-bits), Microsoft Windows Server 2012 (32/64-bits), Windows 8.1 (32/64 bits), Microsoft Windows RT 8.1, Apple MacOS X 10.7 - 10.9
- 3-year warranty
- NAS server
- Bundled Services
- Host Connectivity
- Gigabit Ethernet
- 6 TB
- 8 TB
- 8.7 cm
- 20.5 cm
- 12.8 cm
- 2.4 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- Max Supported Qty
- 1
- RAM
- 512 MB DDR3
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 2 x 3 TB
- Interface Type
- SATA 3Gb/s
- Data Link Protocol
- TCP/IP
- Remote Management Protocol
- HTTP, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
- LDAP support, FTP server, Buffalo Web Access, Apple Time Machine compatible, NTP time synchronisation, SFTP server
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- Expansion Bays
- 2 (total) / 0 (free) x hot-swap
- 1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A
- Device-to-device data replication
- Power Device
- External power adapter
- Voltage Required
- 48 Watt
- Linux
- Software Included
- NovaBACKUP Business Essentials (10 licences)
- OS Required
- Limited warranty - 3 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.86 |
