Buffalo's LinkStation Pro is a high performance, dependable, shared network storage solution with fast transfer speeds. It is easy to install and lets you store and share music, photos, and videos in your home as well as online. Stream your favorite music and videos directly from the LinkStation Pro to a PC or Mac, PS3, Xbox 360, network attached DLNA media player, iPhone or Buffalo LinkTheater. Access and share your multimedia collection from anywhere at any time using WebAccess. Anyone with a web browser and access credentials to your LinkStation will be able to see your photos, videos and other content. The user-friendly LinkStation Pro makes sharing your digital world, simple!
Web access
Upload and watch photos and files or listen to music from anywhere. -
iPhone support
Use your iPhone to stream and view content. -
Time Machine support
Use the LinkStation Pro with Time Machine. -
Eco-friendly
Unit automatically powers down and saves electric cost. -
iTunes support
Play music from the LinkStation through your iTunes application. -
DLNA Certified
It is Built-in media server to stream content. -
BitTorrent client
Download digital content over the Internet directly to your LinkStation Pro. -
Network servers
FTP and print servers included with the firmware. -
Print server
Share existing printers with others in your home or office. -
USB storage support
Connect USB hard drives to back up or add storage. -
Direct copy
Plug in your USB hard drive or camera to quickly offload pictures.
- BUFFALO LinkStation Pro - NAS server - 3 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 3 TB
- 4.5 cm x 15.6 cm x 17.5 cm
- 1.1 kg ()
- Storage Controller
- SATA SATA 3Gb/s
- Hard Drive
- 1 x 3 TB SATA 3Gb/s
- Networking
- Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows XP Media Center Edition 2004, Microsoft Windows 7, Microsoft Windows XP Media Center Edition 2005, Apple MacOS X 10.3.9 or later, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits)
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 3 TB
- 4.5 cm
- 15.6 cm
- 17.5 cm
- 1.1 kg ()
- Built-in Devices
- Print server
Storage Controller
- SATA - internal
- Interface Type
- SATA 3Gb/s
- Supported Devices
- Hard drive
Hard Drive
- HDD
- Capacity
- 1 x 3 TB
- Interface Type
- SATA 3Gb/s
- Data Link Protocol
- TCP/IP, NTP, FTP, SMB
- Remote Management Protocol
- HTTP
- Network Services Compatibility
- Microsoft CIFS, FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
- Print server, iTunes server, FTP server, Buffalo Web Access, BitTorrent Client, Direct Copy
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED
- Expansion Bays
- 1 (total) / 0 (free) x internal
- 1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A
- Power Device
- External power adapter
- Voltage Required
- 24 Watt
- Software Included
- NovaBACKUP Workstation - Buffalo Edition (5 licences)
- OS Required
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
