Buffalo 2TB Terastation Duo NAS
Quicklinx: 631FWS00 Mfr#: TS-WX2.0TL/R1
  • DLNA CERTIFIED
Buffalo's TeraStation Duo is the ideal choice for businesses or demanding users looking to implement a cost effective RAID based Network Attached Storage solution. As the TeraStation III's little cousin, the TeraStation Duo is a dual drive unit that includes all firmware features presently found in the Buffalo lineup of NAS products. In contrast to the TeraStation III 4-drive product, the TeraStation Duo supports RAID 0 and RAID 1 in addition to a simple JBOD configuration. Especially, business oriented features, such Active Directory support, DFS support, disk quota support, a share level replication feature and port trunking make the TeraStation Duo a top choice for small to medium sized businesses. Hardware features like hot swap and dual Ethernet ports add to the list of new features. Reliability and performance are again the key design criteria for the TeraStaion Duo. A heavy-duty power supply and oversized cooling system, as well as vastly improved CPU speed guarantee excellent and reliable performance. It is the clear choice for those users who desire reliability and robust features at an affordable price.
BUFFALO TeraStation Duo TS-WX2.0TL/R1 - NAS server - 2 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
2 TB
2 (installed) / 2 (max)
17 cm x 17 cm x 23 cm
4.5 kg ()
Storage Controller
RAID SATA 3Gb/s RAID 0, 1, JBOD
Hard Drive
2 x 1 TB SATA 3Gb/s
Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
AC 230V (50/60 Hz)
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits)
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
2 TB
17 cm
17 cm
23 cm
4.5 kg ()
Built-in Devices
Status LCD, print server
Storage Controller
RAID - internal
Interface Type
SATA 3Gb/s
Supported Devices
Hard drive, disk array (RAID)
RAID Level
RAID 0, RAID 1, JBOD
Hard Drive
HDD - hot-swap
2 x 1 TB
Interface Type
SATA 3Gb/s
Spindle Speed
7200 rpm
Network / Transport Protocol
TCP/IP, NTP, FTP, SMB
Remote Management Protocol
HTTP
128-bit encryption, BitTorrent Client
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED
Expansion Bays
2 (total) / 0 (free) x internal
2 x USB 2.0 - Type A , 2 x Ethernet 1000Base-T - RJ-45 , 1 x serial RS-232
Internal power supply
AC 230V (50/60 Hz)
47 Watt
Software Included
NovaBACKUP Business Essentials
Limited warranty - 3 years
35 °C
20 - 80%
Resources
The following resources are available for the Buffalo 2TB Terastation Duo NAS
