Buffalo 2TB LinkStation Pro NAS
Quicklinx: 79V8WS00 Mfr#: LS-V2.0TL-EU
Buffalo's LinkStation Pro is a high performance, dependable, shared network storage solution with fast transfer speeds. It is easy to install and lets you store and share music, photos, and videos in your home as well as online. Stream your favorite music and videos directly from the LinkStation Pro to a PC or Mac, PS3, Xbox 360, network attached DLNA media player, iPhone or Buffalo LinkTheater. Access and share your multimedia collection from anywhere at any time using WebAccess. Anyone with a web browser and access credentials to your LinkStation will be able to see your photos, videos and other content. The user-friendly LinkStation Pro makes sharing your digital world, simple!
  • High speed Data Transfer of up to 76MB/s
  • Built-In Media Server Support - Share movies and play music with the DLNA or UPnP Certified media player
  • WebAccess - Access your digital content via a Web browser to a PC or Mac or via the WebAccess-i app to your iPhone, or iPad
  • Direct Copy - One touch transfer of media files from any digital camera/camcorder
  • Built-in BitTorrent Client
  • USB Device server: Connect and share a Multifunction USB 2.0 Printer on your network
Key Specifications
  • 10/100/1000 Gigabit Ethernet support
  • Built-in DLNA & UPnP CERTIFIED Media Server
  • WebAccess - Access your digital content via a Web browser to a PC or Mac or via the WebAccess-i app to your iPhone® or iPad®
  • Direct Copy feature allows you to automatically upload images from your digital camera or digital camcorder directly to your LinkStation
  • Download media directly to your LinkStation using the built-in BitTorrent client, no need to keep your PC on
  • Seamlessly integrates with iTunes® and allows you to access your music files on the LinkStation from your iTunes® software
  • Supports Apple Time Machine Backup with multiple clients
  • Active Directory Support: Works as a client in an Active Directory domain allowing the LinkStation Pro to utilize the domain users and groups
  • Schedule Backups from one LinkStation to another over your LAN network or via USB to an external HDD
  • Includes Novastor NovaBACKUP® Professional with 5 licence Pack for PC
  • TurboPC / TurboCopy for Windows - increases file transferand copy performance
  • Schedule Power Management and PC Interlocking Power Management function
  • Eco Friendly Power Saving Mode
  • Easy setup and web-based administration
  • Protect data by restricting access with group and user level security
  • Built-in Print Server to print from anywhere on your network (*USB printers supported only)
  • Expand storage by adding a USB hard drive via the USB port
  • Built-in FTP server
  • Web access
    Upload and watch photos and files or listen to music from anywhere.
  • iPhone support
    Use your iPhone to stream and view content.
  • Time Machine support
    Use the LinkStation Pro with Time Machine.
  • Eco-friendly
    Unit automatically powers down and saves electric cost.
  • iTunes support
    Play music from the LinkStation through your iTunes application.
  • DLNA Certified
    It is Built-in media server to stream content.
  • BitTorrent client
    Download digital content over the Internet directly to your LinkStation Pro.
  • Network servers
    FTP and print servers included with the firmware.
  • Print server
    Share existing printers with others in your home or office.
  • USB storage support
    Connect USB hard drives to back up or add storage.
  • Direct copy
    Plug in your USB hard drive or camera to quickly offload pictures.
BUFFALO LinkStation Pro - NAS server - 2 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
2 TB
4.5 cm x 15.6 cm x 17.5 cm
1.1 kg ()
Storage Controller
SATA SATA 1.5Gb/s
Hard Drive
1 x 2 TB SATA 1.5Gb/s
Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows XP Media Center Edition 2004, Microsoft Windows 7, Microsoft Windows XP Media Center Edition 2005, Apple MacOS X 10.3.9 or later, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits)
NAS server
Host Connectivity
Gigabit Ethernet
2 TB
4.5 cm
15.6 cm
17.5 cm
1.1 kg ()
Built-in Devices
Print server
Storage Controller
SATA - internal
Interface Type
SATA 1.5Gb/s
Supported Devices
Hard drive
Hard Drive
HDD
1 x 2 TB
Interface Type
SATA 1.5Gb/s
Network / Transport Protocol
TCP/IP, NTP, FTP, SMB
Remote Management Protocol
HTTP
Network Services Compatibility
Microsoft CIFS, FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
Print server, iTunes server, FTP server, Buffalo Web Access, BitTorrent Client, Direct Copy
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED
Expansion Bays
1 (total) / 0 (free) x internal
1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A
External power adapter
24 Watt
Software Included
NovaBACKUP Workstation - Buffalo Edition (5 licences)
5 °C
35 °C
20 - 80% (non-condensing)
Resources
The following resources are available for the Buffalo 2TB LinkStation Pro NAS
