The LinkStation Live II is a Home Multimedia shared network storage device best suited for home environments that need a central location for files that all devices on the network can access. All computers in the network can share files on this versatile, flexible and simple NAS. In addition to the storage capabilities, it can stream multimedia to a PC, a Mac, a Buffalo LinkTheater and other DLNA certified media players. The LinkStation Live seamlessly integrates with iTunes 7 and allowing access to music files from your iTunes software.
Versatile compatibility
Designed to seamlessly integrate with both Mac and PC environments, ensuring a flexible solution for diverse home or office setups. -
High-speed connectivity
Features Gigabit Ethernet for high-speed data transfer, along with support for multiple data link protocols including Ethernet, Fast Ethernet, and Gigabit Ethernet, making file sharing and backups swift and efficient. -
Effortless sharing and streaming
Comes equipped with a BitTorrent Client, Buffalo Web Access, and an iTunes server, offering a variety of options for accessing and enjoying your media files from anywhere.
- BUFFALO LinkStation Live - NAS server - 2 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 2 TB
- 4.5 cm x 15.6 cm x 17.5 cm
- 1.13 kg ()
- Storage Controller
- SATA SATA 1.5Gb/s
- Hard Drive
- 1 x 2 TB SATA 1.5Gb/s
- Networking
- Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
- Power
- AC 120 V (50/60 Hz)
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Apple MacOS X 10.3.9 or later, Microsoft Windows Vista, Microsoft Windows Server 2008
- 1-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 2 TB
- 4.5 cm
- 15.6 cm
- 17.5 cm
- 1.13 kg ()
- Built-in Devices
- Print server
Storage Controller
- SATA - internal
- Interface Type
- SATA 1.5Gb/s
- Supported Devices
- Hard drive
Hard Drive
- HDD
- Capacity
- 1 x 2 TB
- Interface Type
- SATA 1.5Gb/s
- Data Link Protocol
- TCP/IP, NTP, FTP, SMB
- Remote Management Protocol
- HTTP
- Network Services Compatibility
- FTP, Server Message Block (SMB), HTTP
- Print server, iTunes server, FTP server, Buffalo Web Access, BitTorrent Client
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED
- 1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A
- Power Device
- Internal power supply
- Voltage Required
- 17 Watt
- Software Included
- Memeo AutoBackup
- OS Required
- Limited warranty - 1 year
