Buffalo 2TB (4 x 500GB) TeraStation III iSCSI NAS (RAID 0, 1, 5, 10, JBOD) With Gigabit Ethernet & iSCSI)
Quicklinx: 7926WS00 Mfr#: TS-IX2.0TL/R5-EU
Buffalo TeraStation III iSCSI is the perfect RAID storage solution for the small to medium business. This 4 bay, 4 drive, fully populated, affordable storage system uses the existing Ethernet infrastructure to communicate SCSI storage commands over the network. With high speed data transfer speeds of up to 92MB/s, features such as Hot Swap, enabling the removal of faulty hard drives without powering down the device and dual Ethernet ports with support for Port Trunking the TeraStation III iSCSI is the ideal solution to back-up your servers more efficiently, consolidate your existing storage systems and increase redundancy and data security.
BUFFALO TeraStation III iSCSI - NAS server - 2 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
2 TB
4 (installed) / 4 (max)
17 cm x 21.5 cm x 13 cm
8 kg ()
Storage Controller
RAID SATA 1.5Gb/s RAID 0, 1, 5, 10, JBOD
Hard Drive
4 x 500 GB SATA 1.5Gb/s
Network adapter 10Mb LAN, 100Mb LAN, 1GbE
Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows XP Media Center Edition 2004, Microsoft Windows 7, Microsoft Windows XP Media Center Edition 2005, Microsoft Windows Vista, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2008
3-year warranty
NAS server
Host Connectivity
Gigabit Ethernet
2 TB
17 cm
21.5 cm
13 cm
8 kg ()
Built-in Devices
Status LCD
Storage Controller
RAID - internal
Interface Type
SATA 1.5Gb/s
Supported Devices
Hard drive, disk array (RAID)
RAID Level
RAID 0, RAID 1, RAID 5, RAID 10, JBOD
Hard Drive
HDD - hot-swap
4 x 500 GB
Interface Type
SATA 1.5Gb/s
Network adapter
Network / Transport Protocol
TCP/IP, NTP
Network Services Compatibility
HTTP
Trunking
Expansion Bays
4 (total) / 0 (free) x external
2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A
Internal power supply
60 Watt
Limited warranty - 3 years
5 °C
35 °C
20 - 80%
