Buffalo 2TB (1 x 2TB) LinkStation 210 1-Bay NAS
Quicklinx: 99NGWS00 Mfr#: LS210D0201-EU
Capacity: 2TB
Interface: Ethernet, Fast Ethernet, Gigabit Ethernet
Type: 1-Bay
Select:
  • Windows 8.1 (32/64 bits)
48 in stock
£96.60 ex VAT
£115.92 inc VAT
Buffalo Technology's new LinkStation 210D series combines the convenience and capacity of Network Attached Storage with an incredibly easy User Interface and super-quiet fan-less operation.
The LS210 is fast and ready for intensive data storage tasks and can even be set up via Smartphones with a new mobile optimized and intuitive interface.
Buffalo's new LinkStation can also stream up to 4 HD films simultaneously allowing each family member to watch their favorite film, on their own device, at the same time. All of this is combined with a free personal private cloud for remote access from anywhere via apps for Tablets and Smart Phones or via web browsers: keeping all your data at your fingertips no matter where you are.
Buffalo Technology's LS210 series is a single bay Network Attached Storage available fully populated with 2 or 3TB capacity.
BUFFALO LinkStation 210 - NAS server - 2 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
2 TB
Max Supported Capacity
3 TB
4.5 cm x 20.5 cm x 12.8 cm
1.1 kg
1 x Marvell ARMADA 370 800 MHz (Dual-Core)
Storage Controller
SATA SATA 3Gb/s
Hard Drive
1 x 2 TB SATA 3Gb/s
10Mb LAN, 100Mb LAN, GigE
RAM
256 MB
Microsoft Windows XP, Apple MacOS X 10.6 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8, Microsoft Windows RT, Android 2.3 or later, Apple iOS 5.0 or later, Windows 8.1 (32/64 bits), Windows 8.1 RT
NAS server
Host Connectivity
Gigabit Ethernet
2 TB
3 TB
4.5 cm
20.5 cm
12.8 cm
1.1 kg
Enclosure Colour
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
256 MB DDR3
Storage Controller
SATA
Interface Type
SATA 3Gb/s
Hard Drive
HDD
1 x 2 TB
Interface Type
SATA 3Gb/s
Network / Transport Protocol
TCP/IP, Bonjour
Remote Management Protocol
HTTP, HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
Print server, iTunes server, Buffalo Web Access, BitTorrent Client, fanless, DLNA Media Server, Apple Time Machine compatible, NTP time synchronisation
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED
Expansion Bays
1 (total) / 0 (free) x internal
1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A
External power adapter
12 Watt
Software Included
NovaBACKUP Workstation - Buffalo Edition (5 licences)
5 °C
35 °C
20 - 80% (non-condensing)
99NG C2G 2m USB 2.0 A/B Cable - Black In Stock £2.00
99NG C2G 5m USB 2.0 A/B Cable - Black In Stock £5.15
99NG C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £13.16
99NG C2G 12m USB 2.0 A/A Active Extension Cable In Stock £17.24
99NG C2G USB Superbooster Extender Kit In Stock £38.96
99NG C2G USB to HDMI Adapter with Audio Up To 1080p In Stock £42.30
Capacity: 2TB
Interface: Ethernet
Interface: Fast Ethernet
Interface: Gigabit Ethernet
Type: 1-Bay
Brand: Buffalo
Price Range Ex VAT: 50 - 100
