Buffalo 2TB (1 x 2TB) LinkStation 210 1-Bay NAS
Quicklinx: 99NGWS00 Mfr#: LS210D0201-EU
Select:
  • 2TB
  • Windows 8.1 (32/64 bits)
Buffalo Technology's new LinkStation 210D series combines the convenience and capacity of Network Attached Storage with an incredibly easy User Interface and super-quiet fan-less operation.
The LS210 is fast and ready for intensive data storage tasks and can even be set up via Smartphones with a new mobile optimized and intuitive interface.
Buffalo's new LinkStation can also stream up to 4 HD films simultaneously allowing each family member to watch their favorite film, on their own device, at the same time. All of this is combined with a free personal private cloud for remote access from anywhere via apps for Tablets and Smart Phones or via web browsers: keeping all your data at your fingertips no matter where you are.
Buffalo Technology's LS210 series is a single bay Network Attached Storage available fully populated with 2 or 3TB capacity.
  • Efficient storage solution
    The BUFFALO LinkStation 210 offers a 2 TB capacity on a single HDD, making it a choice for individuals or small businesses needing reliable storage. With Serial ATA-300 interface, it ensures fast and efficient data transfer rates.
  • Versatile connectivity
    Equipped with Gigabit Ethernet and USB 2.0 interfaces, this NAS server provides flexible connectivity options. Whether it's connecting to a network for file sharing or directly to a computer for backups, the LinkStation 210 has you covered.
  • Comprehensive compatibility
    Designed to work seamlessly with a wide range of devices, the LinkStation 210 supports Android, Apple iOS, Mac, and PC. This broad compatibility ensures that users can access their files from virtually any device.
  • Advanced networking features
    With support for DLNA, Apple Time Machine, and BitTorrent Client, among others, the LinkStation 210 is more than just storage. It's a multimedia hub that caters to all your entertainment and backup needs.
  • Energy-efficient operation
    The fanless design not only makes the LinkStation 210 quiet but also energy-efficient, with a power consumption of just 12 watts during operation. It's an eco-friendly choice for 24/7 access to your data.
BUFFALO LinkStation 210 - NAS server - 2 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
2 TB
Max Supported Capacity
3 TB
4.5 cm x 20.5 cm x 12.8 cm
1.1 kg ()
1 x Marvell ARMADA 370 800 MHz (Dual-Core)
Storage Controller
SATA SATA 3Gb/s
Hard Drive
1 x 2 TB SATA 3Gb/s
10Mb LAN, 100Mb LAN, 1GbE
RAM
256 MB
Microsoft Windows XP, Apple MacOS X 10.6 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8, Android 2.3 or later, Apple iOS 5.0 or later, Windows 8.1 (32/64 bits), Windows 8.1 RT, Windows RT
NAS server
Host Connectivity
Gigabit Ethernet
2 TB
3 TB
4.5 cm
20.5 cm
12.8 cm
1.1 kg ()
Enclosure Colour
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
Max Supported Qty
1
RAM
256 MB DDR3
Storage Controller
SATA
Interface Type
SATA 3Gb/s
Hard Drive
HDD
1 x 2 TB
Interface Type
SATA 3Gb/s
Network / Transport Protocol
TCP/IP, Bonjour
Remote Management Protocol
HTTP, HTTPS
Network Services Compatibility
Microsoft Active Directory (AD), Microsoft CIFS, FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
Print server, iTunes server, Buffalo Web Access, BitTorrent Client, fanless, DLNA Media Server, Apple Time Machine compatible, NTP time synchronisation
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED
Expansion Bays
1 (total) / 0 (free) x internal
1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A
External power adapter
12 Watt
Software Included
NovaBACKUP Workstation - Buffalo Edition (5 licences)
5 °C
35 °C
20 - 80% (non-condensing)
99NG C2G 2m USB 2.0 A/B Cable - Black In Stock £4.20
99NG C2G 5m USB 2.0 A/B Cable - Black In Stock £4.30
