With Buffalo's Dynamic Random-Access Memory portable hard drive users no longer have to choose between speed and capacity; the HD-PGDU3 series offers both! Buffalo's DDR3 hard drives combine the best of solid state drives - fast speed - with the best of standard hard drives - affordable large capacities.
The HD-PGDU3 is equipped with Buffalo's DDR3 Technology and has an extra-large 1GB cache capable of extremely fast data transfer speeds. The cache works as a buffer during read and write operations allowing the MiniStation to optimize its speed and offer up to 400MB/s write speed and up to 300 MB/s read speed. Ready to copy 1,000 photos? You'll be done in about 3.5 seconds - about 2.3 times faster than a standard USB 3.0 hard drive! Buffalo's portable DDR is sleek and high-design minded, including subtle LEDs which indicate the drive's cache use and power status.
Buffalo's DDR3 MiniStation transfers larger amounts of data fast and reliably and is an excellent choice for video, audio, and graphics professionals, business users, or anyone on-the-go. The HD-PGDU3 series is available in 500GB or 1TB capacities.
Ultra-fast speed
Buffalo's DDR3 hard drives ensure fast speed and affordable large capacities. They are equipped with Buffalo's DDR3 technology and have an extra-large cache capable of extremely fast data transfer speeds. -
Buffalo's Backup Utility
It is a featured backup software thet can be used to back up one or multiple computers with a single Buffalo external hard drive. -
RAMDISK
A simple utility that allows you to create a RAM disk on your PC which creates a small, but extremely fast environment to work on files in. -
TurboPC EX
The solution enhances the performance of Buffalo's TurboPC by boosting data transfer and data copy speeds; thus, making file saving, copying, and transferring even fast -
DDR3 technology
The drive is equipped with Buffalo's DDR3 technology and has an extra-large cache capable of extremely fast data transfer speeds. The cache works as a buffer during read and write operations allowing the MiniStation to optimize its speed and offer higher write and read speeds.
- BUFFALO MiniStation Portable DDR - hard drive - 1 TB - USB 3.0
- Hard drive - external (portable)
- Capacity
- 1 TB
- Interface
- USB 3.0
- Data Transfer Rate
- 5.0 Gbps (USB 3.0)
- Buffer Size
- 1 GB
- DDR3 DRAM Cache, power management support
- Power Source
- USB bus
- Enclosure Colour
- Black
- 8.1 cm x 13.3 cm x 1.8 cm
- 220 g
- 2-year warranty
- Capacity
- 1 TB
- Interface
- USB 3.0
- Buffer Size
- 1 GB
- 8.1 cm
- 13.3 cm
- 1.8 cm
- 220 g
Performance
- Interface Transfer Rate
Expansion & Connectivity
- 1 x USB 3.0 - 10 pin Micro-USB Type B
- Power Source
- USB bus
- Power Consumption
- 5.75 Watt (active)
- Software Included
- Buffalo Tools
- OS Required
- Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple MacOS X 10.4 - 10.9
- Enclosure Colour
- Black
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
