Buffalo 16x2x12x External Blu-rayXL (BDXL) Drive USB 3.0
Quicklinx: BQ8HWS00 Mfr#: BRXL-16U3-EU
Buffalo's MediaStation 16x External BDXL Blu-ray Burner provides high capacity disc writing with fast Blu-ray read and write speeds. Write up to 128 GB of data to a single four layer BDXL disc compared to 25 GB on a traditional single layer Blu-ray disc. It offers optimal burning and playback performance of Blu-ray discs, DVDs and CDs, and includes the CyberLink Media Suite which offers rich Blu-ray and DVD burning and playback tools. Additionally, support for DVD upscaling allows for standard definition DVDs to be viewed and re-recorded in new HD quality. Simply connect MediaStation External BDXL Blu-ray Burner to your computer's USB 3.0 or USB 2.0 port and burn high capacity dics, author Blu-ray discs and DVDs and play back recorded video in high definition.
BUFFALO BDXL drive - SuperSpeed USB 3.0 - external
BDXL drive - external
SuperSpeed USB 3.0
16 cm x 22 cm x 5 cm
1.2 kg
Optical Storage
BDXL
Read Speed
48x (CD) / 16x (DVD) / 12x (BD)
Write Speed
48x (CD) / 16x (DVD±R) / 8x (DVD±R DL) / 16x (BD-R) / 12x (BD-R DL) / 6x (BD-R XL)
CD / DVD Rewrite Speed
24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM) / 2x (BD-RE) / 2x (BD-RE DL) / 2x (BD-RE XL)
SuperSpeed USB 3.0
16 cm
22 cm
5 cm
1.2 kg
Optical Storage
BDXL
Read Speed
Write Speed
Supported Media Types
CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL, BD-R, BD-R DL, BD-RE, BD-RE DL, BD-ROM, BD-ROM DL, BD-R QL, BD-R TL, BD-RE TL, BD-R LTH, BD-R XL
Blu-ray 3D
1 x SuperSpeed USB 3.0 - 9 pin USB Type B
Power adapter
36 Watt
Software Included
CyberLink PowerProducer 5, CyberLink Power2Go 7, CyberLink InstantBurn 5, CyberLink PowerBackup 2, CyberLink PowerDVD 10 BD Edition, Cyberlink MediaShow 5, CyberLink PowerDirector 8 HE
Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
5 °C
35 °C
20 - 80% (non-condensing)
