Buffalo 12x External Blu-ray Drive USB 3.0 with CyberLink Software
Quicklinx: 8DKKWS00 Mfr#: BR3D-12U3-EU
  • BD-RE
The BR3D-12U3 12x External USB 3.0 Blu-ray Drive is ideal for users seeking the best playback and burning performance of Blu-ray discs, DVDs, or CDs on their PCs. The BR3D-12U3 Drive upgrades your computer with an ultra speed Blu-ray Writer that can write up to 50GB, on a double layer Blu-ray disc.
  • USB 3.0
    USB 3.0 supports for the fast Blu-ray read and write performance.
  • USB 2.0 compatible
    Compatible with USB 2.0 systems; max read speed in USB 2.0 is 8x.
  • 3D ready
    It supports the Blu-ray 3D technology for life-like movie experiences with Cyberlink PowerDVD.
  • 2D to 3D DVD conversion
    Convert regular DVD movies into a 3D experience with Cyberlink TrueTheater 3D technology.
  • High Definition Upscaling
    Enjoy standard DVD movies and home videos in HD quality with Cyberlink TrueTheater HD Upscaling technology.
BUFFALO MediaStation 12x External USB 3.0 Blu-ray Writer - BD-RE drive - SuperSpeed USB 3.0 - external
BD-RE drive - external
SuperSpeed USB 3.0
16 cm x 22 cm x 5 cm
1.2 kg
Optical Storage
BD-RE
Read Speed
48x (CD) / 16x (DVD) / 8x (BD)
Write Speed
40x (CD) / 16x (DVD±R) / 8x (DVD±R DL) / 12x (BD-R) / 12x (BD-R DL)
CD / DVD Rewrite Speed
24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM) / 2x (BD-RE) / 2x (BD-RE DL)
Media Load Type
Tray
SuperSpeed USB 3.0
16 cm
22 cm
5 cm
1.2 kg
Optical Storage
BD-RE
Read Speed
Write Speed
Supported Media Types
CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL, BD-R, BD-R DL, BD-RE, BD-RE DL, BD-ROM, BD-ROM DL
Media Load Type
Tray
DVD playback
1 x SuperSpeed USB 3.0 - 4 pin USB Type B
Power supply
24 Watt
Software Included
CyberLink DVD Suite
Microsoft Windows 7, Microsoft Windows XP SP2 or later, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32/64 bits)
5 °C
35 °C
