The BR3D-12U3 12x External USB 3.0 Blu-ray Drive is ideal for users seeking the best playback and burning performance of Blu-ray discs, DVDs, or CDs on their PCs. The BR3D-12U3 Drive upgrades your computer with an ultra speed Blu-ray Writer that can write up to 50GB, on a double layer Blu-ray disc.
USB 3.0
USB 3.0 supports for the fast Blu-ray read and write performance. -
USB 2.0 compatible
Compatible with USB 2.0 systems; max read speed in USB 2.0 is 8x. -
3D ready
It supports the Blu-ray 3D technology for life-like movie experiences with Cyberlink PowerDVD. -
2D to 3D DVD conversion
Convert regular DVD movies into a 3D experience with Cyberlink TrueTheater 3D technology. -
High Definition Upscaling
Enjoy standard DVD movies and home videos in HD quality with Cyberlink TrueTheater HD Upscaling technology.
- BUFFALO MediaStation 12x External USB 3.0 Blu-ray Writer - BD-RE drive - SuperSpeed USB 3.0 - external
- BD-RE drive - external
- Interface
- 16 cm x 22 cm x 5 cm
- 1.2 kg
- Optical Storage
- BD-RE
- Read Speed
- 48x (CD) / 16x (DVD) / 8x (BD)
- Write Speed
- 40x (CD) / 16x (DVD±R) / 8x (DVD±R DL) / 12x (BD-R) / 12x (BD-R DL)
- CD / DVD Rewrite Speed
- 24x (CD) / 6x (DVD-RW) / 8x (DVD+RW) / 5x (DVD-RAM) / 2x (BD-RE) / 2x (BD-RE DL)
- Media Load Type
- Tray
- Power
- AC 120/230 V (50/60 Hz)
- 2-year warranty
- Interface
- 16 cm
- 22 cm
- 5 cm
- 1.2 kg
Optical Storage
- BD-RE
- Read Speed
- Write Speed
- Supported Media Types
- CD-ROM, CD-R, CD-RW, DVD-ROM, DVD-R, DVD-RAM, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL, BD-R, BD-R DL, BD-RE, BD-RE DL, BD-ROM, BD-ROM DL
- Media Load Type
- Tray
- DVD playback
- 1 x SuperSpeed USB 3.0 - 4 pin USB Type B
- Power supply
- Voltage Required
- 24 Watt
- Software Included
- CyberLink DVD Suite
- OS Required
- Microsoft Windows 7, Microsoft Windows XP SP2 or later, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (32/64 bits)
- Limited warranty - 2 years
- 5 °C
- 35 °C
