BT Whole Home Wi-Fi
BT Whole Home Wi-Fi
Quicklinx: F0K2WS00 Mfr#: 088269-BTBD
  • IEEE 802.11n
BT's Whole Home Wi-Fi delivers fast, super-reliable Wi-Fi for every room
Works with all broadband providers
You don’t need to have broadband with BT to use Whole Home Wi-Fi. Just connect the discs to your existing router or hub using the app and you’ll have wi-fi all around your business in minutes.
No more deadspots
With Whole Home Wi-Fi you can have reliable internet connection from the recpetion to the managers office. Three brilliant discs create a complete Wi-Fi network - which means no more deadspots. Even when there are multiple devices connected you still won't lose speed, so you can have devices connected throughout the office and they'll all stay connected, all the time.
The technical bit
Whole Home Wi-Fi is an "intelligent self-configuring wireless network". That means it knows where you and your devices are, and when to switch them from one disc to another to give you the strongest and fastest connection it can. The three discs might be small, but their four built-in AC2600 11ac 2.4GHZ and 5GHZ antennas pack a mighty wireless punch.
Keeping you safe
Whole Home Wi-Fi uses the latest security standards to keep your home network safe from outside interference. And one touch updates mean your business is always protected by the latest up-to-the-minute security patches and upgrades.
With brand new technology, one touch software updates and an app to control it all from, this is Wi-Fi at its simplest. It's Internet that just works.
BT Whole Home Wi-Fi
You're in charge of you network
First, the Whole Home Wi-Fi app tells you just where to put each disc for the best connection. Then once everything's working, it puts you in charge.
A helpful dashboard allows you to see at a glance how your network is being used and who is connected.
Quickly pause the internet completely with one tap.
The disk lights can either be turned them, or off completely depending on where they are placed..
Technical gremlins?
The app will spot - and explain how to fix - them.
Legals - 30 day money back guarantee from date of purchase. The Whole Home Wi-fi app helps you position the discs to ensure you get complete coverage. If you still experience dead spots and are not satisfied you can return the product for a full refund. The product must be undamaged and in the original packaging. Your wi-fi speed will depend on your broadband input speed.
  • Superior Wi-Fi
    Whole Home Wi-Fi helps you find a better location for each disc during set up, shows who is connected and even lets you pause the Internet for some time offline.
  • The technical bit
    Whole Home Wi-Fi is an intelligent self-configuring wireless network. That means it knows where you and your devices are and when to automatically switch them from one disc to another to give you better performance.
  • Stay connected
    The discs create a complete Wi-Fi network, eliminating dead spots and making sure you're connected on every device, everywhere in your home.
BT Whole Home Wi-Fi - Trio - Wi-Fi system - Wi-Fi 5 - desktop
Wi-Fi system
Enclosure Type
Desktop
Wi-Fi System Components
3 access points
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1733 Mbps
Remote Management Protocol
HTTP
Manageable, firmware upgradable, WPA2 encryption, roaming function, WPS, reset button, mobile users support, WPA encryption, band steering, AES encryption, quad-stream (4x4), coloured LED status, self-configuring network
IEEE 802.3, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v
AC 230V (50 Hz)
16.5 cm x 7.7 cm x 16.5 cm
415 g
3-year warranty
Wi-Fi system
3 access points
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1733 Mbps
HTTP
Encryption Algorithm
AES, TKIP, WPA, WPA2, WPS
Wi-Fi Rating
AC2500
Status Indicators
WPS, starting, connection status
Line Properties
Line Coding Format
256 QAM
WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
External power adapter
Installed Qty
3
AC 230V (50 Hz)
7.09 Watt
1 x network cable
16.5 cm
7.7 cm
16.5 cm
415 g
Limited warranty - 3 years
10 - 85%
