Top features
Twinkly projected lightshow featuring stars and moons to help your little one drift off to sleep
3.5" colour Touchscreen LCD display with 480x320 resolution
Pan, tilt and 3x zoom
HD Sound for crystal clear audio so sensitive you can hear your little one breathing
Temperature Display lets you know how hot or cold it is in the nursery
19 Lullabies including classical, nursery rhymes, white noise, nature and womb sounds
The BT Video Baby Monitor 7500 Lightshow gives you peace of mind when your baby is resting or sleeping peacefully. There are a host of features to help your baby drift off to sleep and let you get on with things.
Projected Lightshow and Lullabies
A built in light show projects dreamy images of stars and moons onto the ceiling. The gentle shapes help calm your baby. The 19 built in lullabies feature classical music and traditional nursery rhymes - from Mozart to `Twinkle, twinkle'. It also a white noise generator with specially tested sounds that help babies sleep including ocean waves, simulated womb sounds and even a hairdryer.
Pan, Tilt and Zoom Remotely
You can move the camera remotely from another room easily by using the touchscreen controls on the parent unit. You can even zoom in up to 3 times to check they are really asleep. The camera can rotate 300 degrees around and point down 50 degrees into the cot. This means it is not only a great baby monitor, but also very useful to have in a playroom when your children are a little older.
Double Resolution Touchscreen
The 3.5 inch touchscreen has a fantastic 480x320 pixels resolution. This is double the number of pixels of our previous video monitor, the BT Video 1000. This means you'll have a much better, clearer view of your little one. The display is so advanced, there is even a smartphone style automatic brightness setting. This is great for evenings when you don't want to be disturbed by a bright screen.
HD Sound and Talk Back
Like the other monitors in BT's range, the BT Video 7500 Lightshow has crystal clear HD sound and a talk-back feature. The two way talk-back allows you to calm your baby when you're not in the room, while the Hi-definition Sound is sensitive enough to pick up babies breathing.
Night light
Once your baby is asleep, you won't want to wake him or her up. The adjustable nightlight allows you to find your way around baby's room without having to turn on the main light.
Invisible Infrared Lights
Unlike some video monitors, the night vision lights on the baby unit of the BT 7500 Lightshow are completely invisible when it is dark. This means it's sure not to disturb your child.
Huge Range
It has a huge range of up to 50m indoors and 300m outdoors, so you can be sure to always be in contact as you move around your home.
Other features
There is a dock included for easy charging. The parent unit uses Micro USB for its power cable. This is handy as it means you can also charge it with most other Micro USB chargers. Other features include a mute function, crying alert, low battery alert and out of range alert. The baby unit has a tripod thread and is wall mountable (screws included).
Up to 4 cameras at once
The BT Video 7500 Lightshow supports up to 4 cameras at once. You can watch all 4 on split screen and then easily see one full screen if you hear a noise. The sound feed cycles between each camera or you can choose to switch sound manually between cameras.
So why BT for your baby monitor?
BT has a long history with baby monitors. Our previous monitors have won almost every award under the sun, including the prestigious Which? Best Buy, Mother & Baby Gold and Prima Baby & Pregnancy Platinum.
BT has been the bestselling digital audio baby monitor brand every year since 2010 (Source: NPD 2013).
The BT Video 7500 Lightshow was designed in the UK. We work with real mums and dads throughout our product development to make sure we get the product just right.
So when you want to watch TV or make the dinner in the other room, but want total reassurance that your baby is safe and sound in the cot, the new BT Video Baby Monitor 7500 Lightshow is the Baby Monitor for you.
