BT Verve 450 Quad Cordless Phone With Answer Machine
Quicklinx: 57HKWS00 Mfr#: 035749
Digital Answer Machine
The BT Verve 450 can digitally record up to 15 minutes of messages or up to 59 messages. Each incoming message can last up to a maximum of 1 minute.
Caller Display
If you have subscribed to a Caller Display Service, you will be able to see your caller’s number on your handset display (provided it is not withheld) prior to answering the call. If your caller’s name is stored in the directory and a number match is found, you will see the caller’s name on the display instead.
Wireless Range
The BT Verve 450 has a range of 300 metres outdoors when there is a clear line of sight between the base and handset. With the base indoors and handset either indoors or outdoors, the range will normally be up to 50 metres.
Phonebook
Stores 200 contact numbers for easy dialling. Store a directory entry then copy it – or the entire phonebook – to another BT Verve 450 handset.
Battery Life
In ideal conditions, a fully charged battery should give up to 10 hours talk time or 100 hours standby time on a single charge.
Handsfree
Handsfree lets you talk to your caller without holding the handset. It also enables other people in the room to listen to your conversation over the loudspeaker.
Size of Call List
The Calls list holds up to 20 numbers. The date and time of the call is also stored if available.
GAP Compatible
You can use up to five BT Verve 450 additional handsets with the BT Verve 450 base to extend your phone system without needing to install extension sockets for each new phone.
BT Verve 450 Quad - cordless phone - answering system with caller ID + 3 additional handsets
Cordless phone answering system with caller ID + 3 additional handsets
Total Number of Wireless Handsets
4
Cordless Phone Standard
DECT\GAP
Answering System
Digital
Speakerphone
Caller ID
Call Services
Caller ID
Display
LCD display - monochrome - Yes
Display Features
Inverted
Display (2nd)
LED display - monochrome
Additional Handsets Qty
3
4
Phone Features
DECT\GAP
Call Services
Caller ID
Caller ID Type
Caller ID
Max Handsets Supported
5
Dialer Type
Keypad
Dialer Location
Handset
Conference Call Capability
Speakerphone
Short Messaging Service (SMS)
Volume Control
Ringer Control
Additional Functions
Call timer, built-in clock, Alarm
Phone Memory
Phone Directory Capacity
200 names & numbers
Answering System
Answering System Type
Digital
Recording Capacity
15 min
Message Counter Display
Services
Call Screening
Display
Display Location
Handset
Backlit
Inverted
Display (2nd)
LED display
Colour Support
Monochrome
Display Location
Base
Aerial
Internal
Power adapter, phone charging stand
Phone charging stand + power adaptor - external
Rechargeable
Talk Time
Up to 600 min
Standby Time
Up to 100 h
Resources
The following resources are available for the BT Verve 450 Quad Cordless Phone With Answer Machine
