Refurbished stock with 1 year warranty. Fully tested grade A condition, external packaging may have some minor cosmetic damage.
Expand your existing BT Whole Home Wi-Fi network system with this add-on disc. This additional disc will only work when added to BT's Whole Home Wi-Fi solution to further expand your superfast, super-reliable Wi-Fi network. With a mighty AC2500 wireless punch Whole Home Wi-Fi puts what matters most at your fingertips. It talks to all your gadgets to make sure they're always automatically connected to the fastest and strongest signal. And it's bristling with brilliant controls that put you in charge of a supercharged home network. This is Wi-Fi at its finest. With BT Whole Home Wi-Fi you can have your favorite TV, movies, music and games in any room you wish. No more dead spots. Even when there's a laptop connected in the kitchen, smartphones upstairs and a tablet in the lounge - they all stay connected, all the time.
- BT Whole Home Wi-Fi Add-on disc - radio access point - Wi-Fi 5
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- 16.5 cm x 7.7 cm x 16.5 cm
- 415 g
- 3-year warranty
- 16.5 cm
- 7.7 cm
- 16.5 cm
- 415 g
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1733 Mbps
- Line Coding Format
- 256 QAM
- Frequency Band
- 2.4 GHz, 5 GHz
- Status Indicators
- WPS, starting, connection status
- Manageable, firmware upgradable, WPA2 encryption, roaming function, Wi-Fi Protected Setup (WPS), reset button, mobile users support, WPA encryption, band steering, AES encryption, quad-stream (4x4), coloured LED status, self-configuring network
- Encryption Algorithm
- AES, TKIP, WPA, WPA2, WPS
- IEEE 802.3, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v
Aerial
- Antenna
- Internal
- Antenna Qty
- 4
- 1 x 1000Base-T - RJ-45 (WAN)
- Cables Included
- 1 x network cable
- Power Device
- External power adapter
- 7.09 Watt
- 0 °C
- 40 °C
- 10 - 85%
