Refurbished stock with 1 year warranty. Fully tested grade A condition, external packaging may have some minor cosmetic damage.
Designed specifically for flats and smaller homes, BT's Whole Home Wi-Fi delivers fast, super-reliable Wi-Fi for every room.
Superior Wi-Fi
Whole Home Wi-Fi helps you find a better location for each disc during set up, shows who is connected and even lets you pause the Internet for some time offline. -
The technical bit
Whole Home Wi-Fi is an intelligent self-configuring wireless network. That means it knows where you and your devices are and when to automatically switch them from one disc to another to give you better performance. -
Stay connected
The discs create a complete Wi-Fi network, eliminating dead spots and making sure you're connected on every device, everywhere in your home.
- BT Whole Home Wi-Fi - Trio - Wi-Fi system - Wi-Fi 5 - desktop
- Wi-Fi system
- Enclosure Type
- Desktop
- Wi-Fi System Components
- 3 access points
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 1733 Mbps
- Remote Management Protocol
- HTTP
- Manageable, firmware upgradable, WPA2 encryption, roaming function, WPS, reset button, mobile users support, WPA encryption, band steering, AES encryption, quad-stream (4x4), coloured LED status, self-configuring network
- IEEE 802.3, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v
- Power
- AC 230V (50 Hz)
- 16.5 cm x 7.7 cm x 16.5 cm
- 415 g
- 3-year warranty
- Wi-Fi system
- 3 access points
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 1733 Mbps
- HTTP
- Encryption Algorithm
- AES, TKIP, WPA, WPA2, WPS
- Wi-Fi Rating
- AC2500
- Status Indicators
- WPS, starting, connection status
Line Properties
- Line Coding Format
- 256 QAM
- WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
- Power Device
- External power adapter
- Installed Qty
- 3
- Voltage Required
- AC 230V (50 Hz)
- 7.09 Watt
- Cables Included
- 1 x network cable
- 16.5 cm
- 7.7 cm
- 16.5 cm
- 415 g
- 0 °C
- 40 °C
- 10 - 85%
