BT Refurbished Whole Home Wi-Fi Trio
Quicklinx: DM9QWS00 Mfr#: 095661 REFURB
Select:
  • Trio
  • IEEE 802.11n
Refurbished stock with 1 year warranty. Fully tested grade A condition, external packaging may have some minor cosmetic damage.
Internet from the loft to the cellar. And in every room between.
Staying glued to that box set season finale from living room to bath. Video calling your family on the other side of the world. Changing a fuse, with a YouTube tutorial guiding the way beside you. Sifting through boxes of memories in the loft, to the soundtrack of your teens.
Wherever you are in your home, Whole Home Wi-Fi puts what matters most at your fingertips. It brings super-fast, super-reliable Internet to every room. It talks to all your gadgets to make sure they’re always connected to the fastest and strongest signal. And it’s bristling with brilliant controls that put you in charge of a supercharged home network.
No more deadspots.
With Whole Home Wi-Fi you can have your favourite TV, films, music and games in any room you wish. Three brilliant discs create a complete Wi-Fi network – which means no more notspots. Even when there’s a laptop connected in the kitchen, smartphones upstairs and a tablet in the lounge – they all stay connected, all the time.
The technical bit
Whole Home Wi-Fi is an "intelligent self-configuring wireless network". That means it knows where you and your devices are, and when to switch them from one disc to another to give you the strongest and fastest connection it can. The three discs might be small, but their four built-in AC2600 11ac 2.4GHZ and 5GHZ antennas pack a mighty wireless punch.
Keeping you safe
Whole Home Wi-Fi uses the latest security standards to keep your home network safe from outside interference. And one touch updates mean your home is always protected by the latest up-to-the-minute security patches and upgrades.
It just works
With brand new technology, one touch software updates and an app to control it all from, this is Wi-Fi at its simplest. It’s Internet that just works.
You’re in charge
First, the Whole Home Wi-Fi app tells you just where to put each disc for the best connection. Then once everything’s working, it puts you in charge.
Want to see who’s hogging your connection?
You can see who’s online and how much bandwidth they’re using.
Want to get everyone down for dinner? Or just get some time offline?
Pause the internet completely with one tap.
Disc lights too bright for your bedroom?
Turn them down, or off completely.
Technical gremlins?
The app will spot – and explain how to fix – them.
  • Superior Wi-Fi
    Whole Home Wi-Fi helps you find a better location for each disc during set up, shows who is connected and even lets you pause the Internet for some time offline.
  • The technical bit
    Whole Home Wi-Fi is an intelligent self-configuring wireless network. That means it knows where you and your devices are and when to automatically switch them from one disc to another to give you better performance.
  • Stay connected
    The discs create a complete Wi-Fi network, eliminating dead spots and making sure you're connected on every device, everywhere in your home.
BT Whole Home Wi-Fi - Trio - Wi-Fi system - Wi-Fi 5 - desktop
Wi-Fi system
Enclosure Type
Desktop
Wi-Fi System Components
3 access points
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1733 Mbps
Remote Management Protocol
HTTP
Manageable, firmware upgradable, WPA2 encryption, roaming function, WPS, reset button, mobile users support, WPA encryption, band steering, AES encryption, quad-stream (4x4), coloured LED status, self-configuring network
IEEE 802.3, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11k, IEEE 802.11ac, IEEE 802.11v
AC 230V (50 Hz)
16.5 cm x 7.7 cm x 16.5 cm
415 g
Wi-Fi system
3 access points
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1733 Mbps
HTTP
Encryption Algorithm
AES, TKIP, WPA, WPA2, WPS
Wi-Fi Rating
AC2500
Status Indicators
WPS, starting, connection status
Line Properties
Line Coding Format
256 QAM
WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
External power adapter
Installed Qty
2
AC 230V (50 Hz)
7.09 Watt
1 x network cable
16.5 cm
7.7 cm
16.5 cm
415 g
10 - 85%
