BT Premium Phone - Three Handsets
Quicklinx: D93XWS00 Mfr#: 090632
Type: Cordless phone
Handsets Included: 3
Answer Machine: Yes
Nuisance Call Blocker: Yes
Mounting: Table-top
Select:
22 In Stock
£99.99 ex VAT
£119.98 inc VAT
Express delivery Delivered on Tuesday
Premium Phone
with 100% call blocking and answer machine
Only talk to the people you want to. Block 100% of nuisance calls with the trueCall™ virtual assistant.
Featuring
  • Works with all landline providers
  • 1.8" colour screen
  • Block 100% of nuisance calls1
  • Block up to 1000 numbers1
  • Virtual assistant filters and announces all unknown calls
  • Dedicated call blocking button
  • Do Not Disturb mode
  • Use Bluetooth® to sync contacts from two mobiles
  • Make and receive mobile calls from your home phone
  • Record up to 60 minutes of messages
  • Save up to 1000 contacts
  • Autoshare contacts between handsets
  • Outgoing call control to premium and mobile numbers
  • Redial any of the last 30 calls
  • Handsfree speaker
1 You need to have a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
Fed up with nuisance calls?
Call blocking puts you back in control by allowing you to choose the calls you want to take and those you want to block. This means any caller not on your contact list or already blocked will have to announce their name before getting through so you can choose whether to accept or reject the call. You can also choose to block certain types of call like international or withheld numbers.
Want to sync your mobile and landline?
Using Bluetooth®, you can sync all your contacts between your mobile and Premium Phone and even make and receive your mobile calls through your landline.
Packed with great features
You can save up to 1000 contacts and these are automatically copied to all handsets if you buy a multi pack or register extra handsets. Outgoing call control lets you set a PIN to protect calls to mobile, international and premium rate numbers to prevent any surprises on your bill.
Need an answering machine?
Save up to 60 minutes of messages. You can playback your messages privately through the handset or using the handsfree speaker. And don’t miss important messages when away from home with remote access to your messages.
BT Premium Phone Trio - cordless phone - answering system with caller ID + 2 additional handsets - 3-way call capability
Cordless phone answering system with caller ID + 2 additional handsets
Total Number of Wireless Handsets
3
Cordless Phone Standard
DECT\GAP
Speakerphone
Call Services
Caller ID, Call Transfer, Call Block
Display
LCD display - colour - Yes
Additional Handsets Qty
2
3
Shipping Weight
1.209 kg
Phone Features
DECT\GAP
Call Services
Caller ID Type
Caller ID
Max Handsets Supported
6
Max Handset Operating Distance
50 m
Max Handset Operating Distance (Outdoor)
300 m
Dialer Location
Handset
Conference Call Capability
3-way
Speakerphone
Volume Control
Ring Tones
15
Polyphonic Ringer
Indicators
Visual ringer light
Additional Functions
Call timer, built-in clock, Alarm, Intercom
Phone Memory
Phone Directory Capacity
200 names & numbers
Dialed Calls Memory
30
Answering System
Recording Capacity
60 min
Display
Display Location
Handset
Diagonal Size
1.8"
Backlit
Placing / Mounting
Table-top
AAA type
750 mAh
Rechargeable - Nickel Metal Hydride
Talk Time
Up to 1260 min
Standby Time
Up to 240 h
Dimensions & Weight (Base)
7.7 cm
3.5 cm
9.3 cm
123.6 g
Dimensions & Weight (Handset)
5 cm
4 cm
18.9 cm
116.8 g
Shipping Width
24.5 cm
Shipping Depth
9.4 cm
Shipping Height
19 cm
Shipping Weight
1.209 kg
Resources
The following resources are available for the BT Premium Phone - Three Handsets
Answer Machine: Yes
Mounting: Table-top
Big Button: No
Brand: BT
