BT Mobile Broadband Pre-Pay
Quicklinx: 5GMNWS00 Mfr#: 047799
Mobile Broadband from BT
The BT Mobile Broadband dongle is a small USB modem that plugs into your computer for Internet access at home and on the go.
It gives you Internet access at up to 7.2Mb depending on where you are; the USB modem will automatically connect via the HSDPA, 3G or GPRS network network - with 80% of the UK covered it'll ensure you get the best connection possible.
It comes with 1GB of usage will get you connected to the internet straight away.
With 1GB of usage you can download:
  • 48 photos
  • 144 songs
  • 1 film
  • 300 emails
  • +400 browsing minutes
Or any combination - the above is only a guide and how you use it is up to you.
