BT Home Hub 4 (BT Infinity Customers)
Quicklinx: 8P1XWS00 Mfr#: 068341
  • IEEE 802.11n
New BT Home Hub 4
Our best ever router!
The BT Home Hub 4 is BT's best hub yet. Only BT's new Hub 4 has Smart Dual band technology which reduces wireless interference and drop-outs for the UK's most reliable connection. It has a faster processor that mean it will make any home network faster. With Smart Setup it's easy to set up on any device and you don't need a PC to setup your BT broadband. Plus it has a new slim line design that looks great!
Only BT's Home Hub 4 has smart dual-band technology, for the UK's most reliable wireless connection for all your devices.
Smart dual-band technology which reduces wireless interference and drop out.
Easy set up in just a few minutes. No CD or computer needed, it's all online and works on any device.
Easy wireless connection for any compatible device at the push a button on the Hub without any passwords needed.
Faster processor which allows you to transfer files from one connected device to another faster than ever.
Smart diagnostics which automatically check the Hub is working properly and alert you to any issues and present advice on how to solve them.
Premium design which is sleek and slim.
Ports and Sockets
  • ADSL network interface for BT Broadband
  • 1x RJ45 Gigabit WAN interface for BT Infinity
  • 4x RJ45 Ethernet LAN ports
  • 1x Gigabit Ethernet
  • 3x 10/100 Base T Ethernet
  • 1x USB 2.0 master socket x1
Buttons
  • Wireless: WPS
  • Reset (Pinhole)
  • Restart
  • On/Off power button
LED
  • Power
  • Wireless
1 Year Warranty
