Everyday Phone
with call blocking
[H4] Sub Section Title
Avoid nuisance and unwanted calls. Block up to 20 numbers you don’t want to take calls from.
Features:
- Works with all landline providers
- 1.5 inch amber screen
- Block up to 20 numbers1
- Do Not Disturb mode
- Save up to 50 contacts
- See who’s calling before you pick up1
- Redial any of the last 20 calls
- Adjustable incoming speech volume
1 You need to have a Caller Display service from your network provider to see who’s calling and for the block nuisance calls feature to work. Charges may apply.
Fed up with nuisance calls?
Call Blocking puts you back in control by allowing you to choose the calls you want to take and those you want to block. You can block specific call types, like international and withheld numbers, enter the calls list and select a number that’s called you to block and also store up to 20 specific numbers you don’t want calling you.
Want some peace and quiet?
The Do Not Disturb feature is great for when you need some quiet time, just turn on and your calls will still get through and be added to the calls list but your handset won’t ring.
Want to see who’s calling before you pick up?1
If you subscribe to a Caller Display service, you’ll be able to see your caller’s number on the handset display (provided it’s not withheld) before you answer the call. If your caller’s name is stored in your contacts list and it matches the number calling, you’ll see the caller’s name displayed instead.
1 You need to have a Caller Display service from your network provider to see who’s calling. Charges may apply.
Packed with great features
An easy to set up phone with excellent sound quality. You can save up to 50 contacts and redial any of the last 20 calls you made.
Nuisance Call blocking features
The Everyday Phone can block 20 individual numbers, meaning that you really can avoid speaking to the people you don't want to. -
Do Not Disturb
For those times when you just want some peace and quiet, switch on Block All so that your phone won't ring. If you want key friends and family to still get through, they can do, by tagging them as VIP's in your address book.
- BT Everyday Phone Twin - cordless phone with caller ID + additional handset
- Product Type
- Cordless phone with caller ID + additional handset
- Total Number of Wireless Handsets
- 2
- Cordless Phone Standard
- DECT\GAP
- Call Services
- Call Waiting, Call Transfer
- Display
- LCD display - monochrome - Yes
- Product Type
- Cordless phone
- Additional Handsets Qty
- 1
- 2
Phone Features
- DECT\GAP
- Call Services
- Caller ID Type
- Caller ID
- Max Handsets Supported
- 5
- Max Base Units Supported
- 4
- Max Handset Operating Distance
- 50 m
- Max Handset Operating Distance (Outdoor)
- 300 m
- Dialer Location
- Handset
- Conference Call Capability
- Volume Control
- Ring Tones
- 5
- Handset Locator
- Indicators
- Visual ringer light
- Additional Functions
- Call timer, built-in clock, Alarm, Intercom
Phone Memory
- Phone Directory Capacity
- 50 names & numbers
- Caller ID Memory
- 20 names & numbers
Display
- Display Location
- Handset
- Diagonal Size
- 1.6"
- Backlit
- Placing / Mounting
- Table-top
- Included Accessories
- Phone charging stand
- Battery
- AAA type
- Capacity
- 500 mAh
- Technology
- Rechargeable - Nickel Metal Hydride
- Talk Time
- Up to 600 min
- Standby Time
- Up to 100 h
Dimensions & Weight (Base)
- 10.4 cm
- 11.6 cm
- 4.2 cm
- 86 g
Dimensions & Weight (Handset)
- 5.1 cm
- 3.2 cm
- 16.6 cm
- 94 g
