Essential Phone
with easy call blocking and answer machine
Stay in control of who you speak to by easily blocking nuisance calls from specific numbers and call types.
Featuring
- Works with all landline providers
- 1.8 inch backlit screen
- Block up to 100 numbers1
- Block calls from specific numbers and call types1
- Dedicated call blocking button
- Record up to 30 minutes of messages
- Save up to 100 contacts
- See who’s calling before you pick up1
- Redial any of the last 10 calls
- Handsfree speaker
- Adjustable incoming speech/handsfree volume
1 You need to have a Caller Display service from your network provider for the block nuisance calls feature to work. Charges may apply.
Fed up with nuisance calls?
Call Blocking puts you back in control by allowing you to choose the calls you want to take and those you want to block. You can block specific call types, like international and withheld numbers and use the one touch call blocking button to block an incoming call or if you’ve answered a call, press to stop the number calling again. You can also store up to 100 specific numbers you don’t want calling you.
Packed with great features
An easy to set up phone with excellent sound quality. You can save up to 100 contacts to your phonebook and even set some contacts as VIP callers to ensure they will always get through when Call Blocking is on and set to Allow VIP.
Need an answering machine?
Save up to 30 minutes of messages. You can playback your messages privately through the handset or using the handsfree speaker. And don’t miss important messages when away from home with remote access to your messages.
Want to talk handsfree?
Handsfree lets you talk to your caller without holding the handset, so you’re free to get on with other things, make notes or let other people in the room listen to the conversation over the loudspeaker.
Nuisance Call blocking features
Avoid nuisance and unwanted calls with the Essential Phone. Block up to 100 specific numbers or use the Dedicated Call Block Button to silence your calls. -
Easy set up and great sound quality
Get the most of your phone straight away with the easy to use menu and great sound.
- BT Essential Phone Twin - cordless phone - answering system with caller ID + additional handset
- Product Type
- Cordless phone answering system with caller ID + additional handset
- Total Number of Wireless Handsets
- 2
- Cordless Phone Standard
- DECT\GAP
- Speakerphone
- Call Services
- Call Waiting, Call Transfer, Call Block
- Display
- LCD display - monochrome - Yes
- Product Type
- Additional Handsets Qty
- 1
- 2
Phone Features
- DECT\GAP
- Call Services
- Caller ID Type
- Caller ID
- Max Handsets Supported
- 4
- Max Handset Operating Distance
- 50 m
- Max Handset Operating Distance (Outdoor)
- 300 m
- Dialer Location
- Handset
- Conference Call Capability
- Speakerphone
- Volume Control
- Ring Tones
- 10
- Handset Locator
- Indicators
- Visual ringer light
- Additional Functions
- Call timer, built-in clock, Alarm, Intercom, keyboard lock
Phone Memory
- Phone Directory Capacity
- 100 names & numbers
- Caller ID Memory
- 10 names & numbers
Answering System
- Recording Capacity
- 30 min
Display
- Display Location
- Handset
- Diagonal Size
- 1.8"
- Backlit
- Placing / Mounting
- Table-top
- Battery
- AAA type
- Capacity
- 550 mAh
- Technology
- Rechargeable - Nickel Metal Hydride
- Talk Time
- Up to 720 min
- Standby Time
- Up to 120 h
Dimensions & Weight (Base)
- 9.2 cm
- 4.5 cm
- 12.9 cm
- 128.8 g
Dimensions & Weight (Handset)
- 5.1 cm
- 3.5 cm
- 17.8 cm
- 123.2 g
