BT Essential Digital Home Phone
Quicklinx: G4Z9WS00 Mfr#: 090709
Type: Cordless phone
Handsets Included: 1
Answer Machine: No
Nuisance Call Blocker: Yes
Mounting: Table-top
12 left in stock
£24.99 ex VAT
£29.98 inc VAT
Essential Digital Home Phone with crystal clear HD calling and easy access to both call blocking and Voice Mail.
  • HD Voice for excellent sound quality
  • Easy set up
  • One touch access to BT 1571 voicemail
  • See and hear if you have a second call waiting
  • Call Diversion so you never miss a call
  • Connects to your Smart Hub 2
  • Multi Call – so two people can be on the phone at the same time
  • Easy to read screen shows when you have messages
  • Save up to 500 contacts
  • Redial any of the last 30 calls you made
  • Long range reception, up to 300m outdoors, 50m indoors
Easy set up and great sound quality
Get the most out of your phone straight away with our easy to use menu. And enjoy high quality clear calls, with HD calling.
Want to be able to stop nuisance calls?
Block all your unwanted calls with BT Call Protect
No more arguments when the phones busy
With Multi Call, two people can make calls at the same time
Answer Machine: No
Mounting: Table-top
Big Button: No
Brand: BT
Stock Status: While stocks last
Stock Status: Clearance
