BT Elements 1K Single
Quicklinx: B02KWS00 Mfr#: 079482
Type: Cordless phone
Handsets Included: 1
Answer Machine: [N/A]
Nuisance Call Blocker: No
Mounting: Wall-mountable, Table-top
Hurry, only 1 left in stock!
£74.99 ex VAT
£89.98 inc VAT
Express delivery Order within the next 7 hours for delivery tomorrow
BT Elements 1km range IP67 Rated Cordless Phone with Answer Machine and Nuisance Call Blocker
The BT Elements 1 km long range IP67 rated Cordless Phone with Answer Machine with up to 30 mins recording time and Nuisance Call Blocker. More rugged, more robust and far more aesthetically pleasing than its predecessor this BT Elements is ideal for the workshop, the warehouse, the outdoors or even just at home with the kids.
This robust BT Elements is IP67 rated meaning this ruggedised handset is protected from dust and water immersion (depth between 15 cm and 1 m for up to 30 mins).
This phone also has a long cordless outdoor range of up to 1 km and up to 50 m indoors.
Nuisance Call Blocking Technology installed
Fed up with unwanted calls interrupting you at home or at work? This phone's Nuisance Call Blocker puts you back in control by enabling you to choose the calls you want to take and those you want to block.
With up to 13 hrs talktime, up to 160 hrs standby time, handy belt clip and handsfree feature, this phone will let you move around freely when life gets busy. The integrated answer machine also makes sure you never miss an important message should you miss or not be able to take a call. This phone also supports SMS text messaging and features a clock, calendar and alarm.
Other useful features
  • 200 name and number directory
  • a handy 6 line mono display which is backlit and has contrast control
  • 50 number calls list
  • 30 number redial list
  • call waiting indicator
  • 10 polyphonic and 5 standard ringtones
  • a VIP indicator
  • 9 quick dial memories
  • a keypad lock and secrecy function
BT Elements 1K - cordless phone - answering system with caller ID - 3-way call capability
Cordless phone answering system with caller ID
Total Number of Wireless Handsets
1
Cordless Phone Standard
DECT\GAP
Intercom
Speakerphone
Call Services
Call Waiting, Call Transfer, Call Hold
Display
LCD display - monochrome - Yes
Body Colour
Grey, black
1-year warranty
1
Body Colour
Grey, black
Phone Features
DECT\GAP
Call Services
Caller ID Type
Caller ID
Max Handsets Supported
5
Max Base Units Supported
4
Max Handset Operating Distance
50 m
Max Handset Operating Distance (Outdoor)
1000 m
Dialer Type
Keypad
Dialer Location
Handset
Conference Call Capability
3-way
Intercom
Speakerphone
Short Messaging Service (SMS)
Menu Operation
Ring Tones
15
Polyphonic Ringer
Handset Locator
Indicators
Visual ringer light
Additional Functions
Call timer, built-in clock, Alarm, Intercom
Additional Features
Outside line remote, out of range alert, key lock, PIN code, music on hold
Phone Memory
Phone Directory Capacity
200 names & numbers
Dialed Calls Memory
30
Caller ID Memory
50 names & numbers
Answering System
Outgoing Announcements Qty
1
Max Incoming Message Length
3 min
Recording Capacity
30 min
Memo Record Function
Services
Call Screening
Display
Display Location
Handset
Backlit
Placing / Mounting
Wall-mountable, table-top
Belt clip, power adapter, phone charging stand
550 mAh
Rechargeable - Lithium Ion
Talk Time
Up to 600 min
Standby Time
Up to 250 h
Dimensions & Weight (Base)
12.8 cm
6.45 cm
12.6 cm
161 g
Dimensions & Weight (Handset)
5.5 cm
3.1 cm
19.6 cm
172 g
Limited warranty - 1 year
Resources
The following resources are available for the BT Elements 1K Single
Mounting: Table-top
Big Button: No
Brand: BT
