BT Duet 210
Quicklinx: 7SSCWS00 Mfr#: 061125
Duet 210
wall mountable with hearing aid compatibility
An easy to use corded phone with 10 number memory and hearing aid compatibility.
Featuring
  • Works with all landline providers
  • Easy to set up and simple to use
  • Excellent sound quality
  • Hearing aid compatible
  • Save up to 10 contacts
  • Last number redial
  • Wall mountable
  • Secrecy feature, put your caller on mute
  • Adjustable ringer volume
  • Incoming call indicator light
Packed with great features
You can place the phone on a desk or table or if more convenient it can be wall mounted. When on a call, you can use the mute feature to talk to someone in the same room without your caller hearing and there’s a handy one touch redial button to easily redial the last number called.
Quickdial memory
For easy dialling, you can save 10 of your most frequently dialled phone numbers under the quickdial memory buttons. There’s also a quickdial memory card located on the base of the phone to remind you which phone number is stored under each button.
BT Duet 210 - corded phone
Corded phone
Speed Dial Capacity
10
Body Colour
White
1 year warranty
Corded phone
Body Colour
White
Phone Features
Dialer Type
Keypad
Dialer Location
Handset
Function Buttons
Mute button, auto redial button
Volume Control
Ringer Control
Ring Tones
1
Indicators
Visual ringer light
Phone Memory
Speed Dial Capacity
10
Hearing Aid Compatible
Placing / Mounting
Wall-mountable, table-top
Resources
The following resources are available for the BT Duet 210
