BT Digital Voice Adapter
Quicklinx: HFPVWS00 Mfr#: 100121-BT6
This Adapter allows you the freedom to keep using your existing home phones when your service moves to Digital Voice. If your current home phone is a DECT Cordless phone, with or without additional handsets, you will only need 1 Adapter.
If you only use Corded phones in your home, you will need an Adapter per phone. (You can have up to 5 Digital Voice products registered to the Smart Hub 2, this includes the Digital Voice Adapter)
You require an adapter if:
  1. You want your DECT phone in a different location to your Smart Hub. You’ll only need 1 Adapter
  2. You use Corded phones around your house. You’ll need an Adapter per Corded phone
You do not need an adapter if:
  • It’s convenient for you to plug either your Corded or Cordless phone directly into the green port at the back of your Smart Hub 2.
