BT Decor 2200
Quicklinx: 7SS7WS00 Mfr#: 061127
Type: Corded phone
Handsets Included: 1
Answer Machine: No
Nuisance Call Blocker: No
Mounting: Table-top
10 In Stock
£24.99 ex VAT
£29.98 inc VAT
Express delivery Order within the next 2 hours for delivery tomorrow
Decor 2200
with handsfree speaker
An easy to use corded phone that’s compatible with hearing aids.
Featuring
  • Works with all landline providers
  • Easy to set up and simple to use
  • Big buttons
  • Excellent sound quality
  • Hearing aid compatible
  • Save up to 50 contacts
  • Handsfree speaker
  • Secrecy feature, put your caller on mute
  • Last number redial
  • See who’s calling before you pick up1
  • Calls light indicator
  • One touch 1571 button2
1You need to have a Caller Display service from your network provider to see who’s calling. Charges may apply.
2To use the 1571 voicemail feature you must subscribe to your network provider’s network answering service and batteries must be installed.
Packed with great features
For easy dialling, you can save up to 50 contacts in the phonebook and redial the last number called. When on a call, you can use the mute feature to talk to someone in the same room without your caller hearing.
Want to talk handsfree?
Handsfree lets you talk to your caller without holding the handset, so you’re free to get on with other things, make notes or let other people in the room listen to the conversation over the loudspeaker. The green light on the handsfree button will illuminate when handsfree mode is on.
Want to see who’s calling before you pick up?1
If you subscribe to a Caller Display service, you’ll be able to see your caller’s number on the handset display (provided it’s not withheld) before you answer the call. If your caller’s name is stored in your phonebook and it matches the number calling, you’ll see the caller’s name displayed instead. There’s a Calls list that holds the numbers (and names if there’s a match with the phonebook) of your last 30 received calls.
Easy access to BT 15712
If you’ve subscribed to your network’s answering service like BT Answer 1571 or Call Minder, you can press the 1571 button to easily access the service and listen to your messages. The green light will flash when you have new messages waiting.
2 To use the 1571 voicemail feature you must subscribe to your network provider’s network answering service and batteries must be
BT Decor 2200 - corded phone with caller ID/call waiting
Corded phone with caller ID/call waiting
Speakerphone
Caller ID
Call Services
Caller ID, Call Waiting, Message Waiting Capability
Display
LCD display - monochrome
Body Colour
White
1-year warranty
Corded phone
Body Colour
White
Phone Features
Call Services
Caller ID Type
Caller ID/call waiting
Dialer Type
Keypad
Dialer Location
Base
Speakerphone
Menu Operation
Function Buttons
Speakerphone button, recall button, directory button, navigator key, 1571, mute button, auto redial button
Volume Control
Ringer Control
Ring Tones
3
Indicators
Visual ringer light, voice message waiting indicator
Additional Functions
Call timer, built-in clock, built-in calendar
Phone Memory
Phone Directory Capacity
50 names & numbers
Caller ID Memory
30 names & numbers
Display
Display Location
Base
Line Qty
3
Hearing Aid Compatible
Phone line cable
4 x battery - AA type
Included Qty
4
Dimensions & Weight (Base)
20 cm
16 cm
9 cm
499 g
Limited warranty - 1 year
Resources
The following resources are available for the BT Decor 2200
Type: Corded phone
Answer Machine: No
Mounting: Table-top
Big Button: No
Brand: BT
