BT Decor 1200 Corded Phone Silver and White
Quicklinx: 4CYLWS00 Mfr#: 024863
With ten number memory, Caller display, and an inductive coupler, the BT Decor 1200 is a great business or home office phone.
Top Features
  • 10 number memory
  • Handsfree
  • Volume control
  • Message waiting Indicator
  • Inductive coupler
  • BT Services programmed into directory (can be overwritten)
In order to see who is calling, you will need to subscribe to the BT Caller Display Service for the caller display function on this phone to be activated. The Caller Display Service is available at no extra cost when you sign up to BT's Privacy at Home service. It helps you take control of incoming calls with BT Caller Display and also helps you reduce unwanted sales calls with Telephone Preference Service
Where described as VoIP compatible, this applies when used with the appropriate VoIP service such as BT's Broadband Talk service and hardware such as the BT Home Hub - it is not a standalone voip phone
BT Decor 1200 - corded phone with caller ID
Corded phone with caller ID
Speakerphone
Caller ID
Call Services
Caller ID
Speed Dial Capacity
10
Display
LCD display - monochrome
Body Colour
Chalk white
1-year warranty
Corded phone
Body Colour
Chalk white
Phone Features
Call Services
Caller ID
Caller ID Type
Caller ID
Dialer Type
Keypad
Dialer Location
Base
Speakerphone
Function Buttons
Recall button, 1571, memory pause button, mute button
Volume Control
Ringer Control
Indicators
New call indicator
Additional Functions
Built-in clock
Phone Memory
Phone Directory Capacity
50 names & numbers
Dialed Calls Memory
1
Speed Dial Capacity
10
One-Touch Dial Button Qty
3
Display
Display Location
Base
Placing / Mounting
Wall-mountable, table-top
Limited warranty - 1 year
Resources
The following resources are available for the BT Decor 1200 Corded Phone Silver and White
