Converse 2100
with headset socket
An easy to use corded business phone with a headset socket.
Featuring
- Works with all landline providers
- Easy to set up and simple to use
- Excellent sound quality
- Headset socket
- Speed dial up to 3 numbers
- Hearing aid compatible
- Secrecy feature, put your caller on mute
- Last number redial
- Incoming voice amplification
- Message waiting indicator1
- Incoming calls light indicator
1 The light will only flash when connected to a PBX switch or similar. The light will not flash when used with network services e.g. BT 1571.
Packed with great features
For easy dialling of your 3 most frequently used phone numbers, you can save 3 speed dial numbers under the one touch memory buttons and redial the last number called at the touch of a button. When on a call, you can use the mute feature to talk to someone in the same room without your caller hearing.
Make calls using a headset
For flexibility while working and taking calls, there’s a headset socket so you can plug a headset in with an RJ11 jack and talk to your caller without holding the handset and be free to type or make notes at the same time.
- BT Converse 2100 - corded phone
- Product Type
- Corded phone
- Voice Mail Capability
- Call Services
- Voice Mail
- Body Colour
- White
- Product Type
- Corded phone
- Body Colour
- White
Phone Features
- Call Services
- Voice Mail
- Dialer Type
- Keypad
- Dialer Location
- Base
- Dialing Modes
- Pulse, tone
- Function Buttons
- Recall button, headset button, amplify button, mute button, auto redial button
- Volume Control
- Ringer Control
- Indicators
- Visual ringer light, voice message waiting indicator
- Additional Features
- Incoming sound amplifier
Phone Memory
- One-Touch Dial Button Qty
- 3
- Connections
- Headset jack
- Placing / Mounting
- Wall-mountable, table-top
- Cables Included
- Phone line cable
Jabra Pro 920 Wireless Headset - Deskphone Only | In Stock | £125.34 |
