BT Converse 2100 White Corded Phone
Quicklinx: 5FH1WS00 Mfr#: 040205
Type: Corded phone
Handsets Included: 1
Answer Machine: [N/A]
Nuisance Call Blocker: No
Mounting: Table-top, Wall-mountable
Colours:
£18.33 ex VAT
£21.99 inc VAT
Express delivery Order within the next hour for delivery tomorrow
Converse 2100
with headset socket
An easy to use corded business phone with a headset socket.
Featuring
  • Works with all landline providers
  • Easy to set up and simple to use
  • Excellent sound quality
  • Headset socket
  • Speed dial up to 3 numbers
  • Hearing aid compatible
  • Secrecy feature, put your caller on mute
  • Last number redial
  • Incoming voice amplification
  • Message waiting indicator1
  • Incoming calls light indicator
1 The light will only flash when connected to a PBX switch or similar. The light will not flash when used with network services e.g. BT 1571.
Packed with great features
For easy dialling of your 3 most frequently used phone numbers, you can save 3 speed dial numbers under the one touch memory buttons and redial the last number called at the touch of a button. When on a call, you can use the mute feature to talk to someone in the same room without your caller hearing.
Make calls using a headset
For flexibility while working and taking calls, there’s a headset socket so you can plug a headset in with an RJ11 jack and talk to your caller without holding the handset and be free to type or make notes at the same time.
BT Converse 2100 - corded phone
Corded phone
Voice Mail Capability
Call Services
Voice Mail
Body Colour
White
Corded phone
Body Colour
White
Phone Features
Call Services
Voice Mail
Dialer Type
Keypad
Dialer Location
Base
Dialing Modes
Pulse, tone
Function Buttons
Recall button, headset button, amplify button, mute button, auto redial button
Volume Control
Ringer Control
Indicators
Visual ringer light, voice message waiting indicator
Additional Features
Incoming sound amplifier
Phone Memory
One-Touch Dial Button Qty
3
Headset jack
Placing / Mounting
Wall-mountable, table-top
Phone line cable
Resources
The following resources are available for the BT Converse 2100 White Corded Phone
Type: Corded phone
Mounting: Table-top
Mounting: Wall-mountable
Big Button: No
Brand: BT
Stock Status: While stocks last
Stock Status: Clearance
