Brand
BT Converse 2100 Black corded phone
Quicklinx: 5FH2WS00 Mfr#: 040206
Type: Corded phone
Handsets Included: 1
Answer Machine: [N/A]
Mounting: Wall-mountable, Table-top
Colours:
28 In Stock
£27.49 ex VAT
£32.98 inc VAT
Express delivery Delivered on Tuesday
Converse 2100
with headset socket
An easy to use corded business phone with a headset socket.
Featuring
  • Works with all landline providers
  • Easy to set up and simple to use
  • Excellent sound quality
  • Headset socket
  • Speed dial up to 3 numbers
  • Hearing aid compatible
  • Secrecy feature, put your caller on mute
  • Last number redial
  • Incoming voice amplification
  • Message waiting indicator1
  • Incoming calls light indicator
1 The light will only flash when connected to a PBX switch or similar. The light will not flash when used with network services e.g. BT 1571.
Packed with great features
For easy dialling of your 3 most frequently used phone numbers, you can save 3 speed dial numbers under the one touch memory buttons and redial the last number called at the touch of a button. When on a call, you can use the mute feature to talk to someone in the same room without your caller hearing.
Make calls using a headset
For flexibility while working and taking calls, there’s a headset socket so you can plug a headset in with an RJ11 jack and talk to your caller without holding the handset and be free to type or make notes at the same time.
1 Year Warranty
Resources
The following resources are available for the BT Converse 2100 Black corded phone
Type: Corded phone
Mounting: Table-top
Brand: BT
