BT BT Decor 1300 Corded Phone
Quicklinx: 4CYMWS00 Mfr#: 024864
The BT Decor 1300 has a two line LCD screen with contrast control, Caller Display, a clock with date, day and month. It has features such as polyphonic ring tones, 100 names and numbers directory, control, time and date stamp, store, secrecy, pause and recall buttons. Wall mountable, it is PBX compatible and supports TouchTone dialing.
Key Features:
  • LCD screen
  • Ring indicator light
  • Polyphonic ring tones - 0
  • Pause
  • Recall
  • Last number redial
  • Ringer hi-low-off
  • Secrecy
  • Mute button
  • Store button
  • Touch tone dialling compatible
  • Wall mountable
  • 1571 network message detection
  • Speech amplification volume control
  • Speaker Volume Control
  • Pre-dialling facility
*In order to see who is calling you will need to subscribe to the BT Caller Display Service which is available when you sign up to www.bt.com/btprivacy BT residential customers making some calls on the BT network can opt in to receive Caller Display at no extra charge, subject to availability. Analogue lines only. Numbers will not be registered if the call is from payphones, some switchboards, and non-BT networks or where a caller's number is withheld.
Where described as VoIP compatible, this applies when used with the appropriate VoIP service such as BT's Broadband Talk service and hardware such as the BT Home Hub - it is not a standalone voip phone
BT Decor 1300 - corded phone with caller ID
Corded phone with caller ID
Speakerphone
Caller ID
Call Services
Caller ID
Speed Dial Capacity
10
Display
LCD display - monochrome
Body Colour
Arctic grey
1-year warranty
Corded phone
Body Colour
Arctic grey
Phone Features
Call Services
Caller ID
Caller ID Type
Caller ID
Dialer Type
Keypad
Dialer Location
Base
Speakerphone
Menu Operation
Function Buttons
Recall button, 1571, memory pause button, mute button
Volume Control
Ringer Control
Additional Functions
Call timer, built-in clock, Time/Day Stamp
Phone Memory
Phone Directory Capacity
100 names & numbers
Dialed Calls Memory
1
Speed Dial Capacity
10
Display
Display Location
Base
Line Qty
2
Placing / Mounting
Wall-mountable
Limited warranty - 1 year
Resources
The following resources are available for the BT BT Decor 1300 Corded Phone
