BT Big Button 200
Quicklinx: 7SS3WS00 Mfr#: 061130
Type: Corded phone
Handsets Included: 1
Answer Machine: No
Nuisance Call Blocker: No
Mounting: [N/A]
20 In Stock
£23.33 ex VAT
£27.99 inc VAT
Express delivery Order within the next 20 hours for delivery on Tuesday
Big Button 200
with hearing aid compatibility and handsfree speaker
An easy to use big button phone.
Featuring
  • Works with all landline providers
  • Hearing aid compatible
  • Excellent sound quality
  • Easy to use big buttons
  • Handsfree speaker
  • Amplifier to boost incoming and outgoing handset volume
  • Save up to 10 contacts
  • Quick dial 3 contacts
  • LED call indicator
  • One touch 1571 button1
1 To use the 1571 voicemail feature you must subscribe to your network provider’s network answering service and batteries must be installed. Charges may apply.
Struggling to enter numbers accurately or hear callers?
This is the ideal phone for anyone with sight, hearing or dexterity challenges. The big buttons will ease the frustration of entering numbers incorrectly. It’s hearing aid compatible and you can even boost the volume of your caller’s voice and your own voice to make sure you can hear and be heard clearly.
Want to talk handsfree?
Handsfree lets you talk to your caller without holding the handset, so you’re free to get on with other things, make notes or let other people in the room listen to the conversation over the loudspeaker. The green LED on the handsfree button will illuminate to show you when handsfree is switched on.
Need to dial numbers quickly and easily?
Save up to 10 contacts in the quick dial memory and for easy dialling of your most important numbers there’s 3 one-touch memory buttons. There’s a one-touch and quick dial memory card on the base so you can make a note of the numbers you’ve saved. You can also redial the last number you called with the touch of a button.
Easy access to BT 15711
If you’ve subscribed to your network’s answering service like BT Answer 1571 or Call Minder, you can press the 1571 button to easily access the service and listen to your messages. The green LED will flash when you have new messages waiting.
BT Big Button 200 - corded phone
Corded phone
Speakerphone
Voice Mail Capability
Call Services
Voice Mail, Message Waiting Capability
Speed Dial Capacity
10
Body Colour
White
1-year warranty
Corded phone
Body Colour
White
Phone Features
Call Services
Dialer Type
Keypad
Dialer Location
Base
Speakerphone
Function Buttons
Recall button, amplify button, 1571, auto redial button
Volume Control
Ringer Control
Ring Tones
3
Indicators
Low battery indicator, visual ringer light, voice message waiting indicator, speakerphone indicator
Additional Features
Large buttons, incoming sound amplifier, outgoing sound amplifier
Phone Memory
Speed Dial Capacity
10
One-Touch Dial Button Qty
3
Hearing Aid Compatible
Phone line cable
4 x battery - AA type
Included Qty
4
Dimensions & Weight (Base)
22 cm
18 cm
10.1 cm
0.63 kg
Limited warranty - 1 year
Resources
The following resources are available for the BT Big Button 200
Type: Corded phone
Answer Machine: No
Mounting: [N/A]
Big Button: Yes
Brand: BT
